Heat proof exhaust paint on Intercooler...
Postby ~SlideWays~ » Wed Feb 28, 2007 10:58 am
This topic has been partly discussed before, but not much info.
The paint is the VHT stuff you'd use on your exhaust manifold, heat proof to 1350degree's from memory.
Now does this paint keep the heat IN to a certain extent, or is it just "heat proof" in the way that it won't crack/peal off at high temps?
I want to put a light matte black coat onto my intercooler to hid it from prying eye's. Would this paint suit or would it lower its cooling effiency?
Any suggestion on what else could be used would be great. (I've already got a can of the VHT stuff left over anyway though).
~SlideWays~
Postby big_boy » Wed Feb 28, 2007 2:47 pm
i dont see why it would make it any worse for cooling as radators have it on them
but i am sure that that paint dousent effect the heat it just dousent chip & crack ect
for sale EE90
big_boy
Postby bluemaumau » Wed Feb 28, 2007 5:08 pm
doesnt it distribute the heat better
Postby aesc » Thu Mar 01, 2007 8:10 am
I think that heat proof paint is just more resistant to higher temps, it doesnt have any 'thermal' properties so wont keep heat in. However black does dissipate heat better than say chrome
I think there was discussion that the paint could clog up the fins and affect the cooling ability. Apparently anodising intercoolers is the way to go
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Stealer Of Souls » Thu Mar 01, 2007 8:22 am
I would think it pretty hard to manage to block up the fins with spray paint if you were careful about it.
And IMO any insulating effects from a layer of paint would be pretty insignificant.
Anodising would be better...
'86 AE85.5 Levin
Stealer Of Souls
Postby Pelo » Thu Mar 01, 2007 7:32 pm
Ask at a radiator shop, apparently there is a special paint they use specifically for radiators.
Pelo
Postby Adoom » Thu Mar 01, 2007 7:46 pm
Geez Gav. All it does is not peel in the 600degree heat it has no other 'special' properties..... And you call yourself a James boy!!!???
Adoom
