wrapping 3sgte St205 IC
Postby dougsop » Fri Mar 02, 2007 12:53 pm
planning to wrap the Intercooler Core of my st205.
what sort of material is best for this job and where about can i get it ?
thank you
97 Toyota GT4 ST205 1st run 16.2psi 181.2KW
more to come...
dougsop
Postby MrOizo » Fri Mar 02, 2007 12:57 pm
like this?
PM Running Rich for details i guess :)
MrOizo
Toyspeed Legend
Postby RunningRich » Fri Mar 02, 2007 2:48 pm
Photo thief! :P
It is the stick on metallic film you get from speed shops. Can't remember the brand name off hand, but it's the crowd that to the exhaust wrap. I bought it in Canberra but places like greenlane speed shop may help.
Clean the IC well with solvent. Mine is still secure 60000km+ later.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby dougsop » Fri Mar 02, 2007 3:25 pm
MrOizo wrote:like this?
yes like that, where abt in auckland to you get it :D
engine light is flashing if i get stuck in traffic, i belive its the IC cause the intake air to raise ?
more to come...
dougsop
Postby sergei » Fri Mar 02, 2007 3:32 pm
Check your water level in I/C.
But before that check the codes first.
Engine light should not flash if you have hot water there...
Postby no_8wire » Fri Mar 02, 2007 4:24 pm
You can also get similar stuff from plumbing shops for hot water cylinders... 8)
no_8wire
Postby Prymal » Fri Mar 02, 2007 6:06 pm
or just bridge the plug , remove code 54 and run a frontmount Air to air
if you want to retain stockish power levels the WTA is fine but youll soon find its limitations if you start chasing power..
its sorta good , not having to worry about water pump failures , or sensors throwing codes , which are two things that have a minus against the WTA , plus the weight of the thing and the drain on the alternator
Whot id love to see though if you plan on doing this is a befor and after Air intake temperature - see if you can plumb in a simple sensor and see if lagging the cooler does have a benifit thats noticable
Prymal
Postby sergei » Fri Mar 02, 2007 7:49 pm
I disagree stock W/A is very good system - it will suffice for anything near 400-450Hp in my opinion. Just the lag you will get with A/A is not worth it.
Postby Prymal » Fri Mar 02, 2007 9:47 pm
to be honest i didnt notice really all that much drop from a standard A to A to a frontmount where lag was concerned
there was a tune done between swaps , but a <20 Degree intake temp was worth a few milliseconds of hesitation , and that was withut additional help of WI or a spraybar
Prymal
Postby sergei » Fri Mar 02, 2007 9:50 pm
You had stock A/A? Thats makes big difference.
I get about 40'C inlet temp max with 1.2+ Bar boost with ST205 I/C.
Postby dougsop » Fri Mar 02, 2007 11:01 pm
well also consider the cost of the FMIC, i think wrapping the WAI is the most efficient way.
just need to knwo where to get the wrapping material in AKL :D
more to come...
dougsop
Postby no_8wire » Sat Mar 03, 2007 9:30 am
no_8wire wrote:You can also get similar stuff from plumbing shops for hot water cylinders... 8)
Try mastertrade and mitre10
no_8wire
Postby dougsop » Sun Mar 04, 2007 3:41 pm
ok, i've got some sort of floor insulating sheet now, but wat do i use to stick in on to the IC ?
do i need something heat resistance ?
and should i wrapp the whole IC or just the bottom?
more to come...
dougsop
