when running the nite[arts belhousing whoch backing plate should be used? t50? k50?
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
By backing plate you mean the plate on the back of the motor between the box? Its not dependant on gearbox but engine. theres a FWD and RWD one, FWD would be perferred then make up the lower part of dust shield yourself with a plate of tin.
