w55 to 4age
w55 to 4age
Postby ke_25 » Fri Mar 02, 2007 1:06 pm
when running the nite[arts belhousing whoch backing plate should be used? t50? k50?
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby Jebus » Fri Mar 02, 2007 1:18 pm
By backing plate you mean the plate on the back of the motor between the box? Its not dependant on gearbox but engine. theres a FWD and RWD one, FWD would be perferred then make up the lower part of dust shield yourself with a plate of tin.
Jebus
Postby thaphatty » Fri Mar 02, 2007 3:20 pm
one would assume the night parts bellhousing places the clutch fork on the right, and the starter on the left, so you'd want a 3A AE85 backing plate.
I've got one i dont need. pm if you want it
thaphatty
