Gear stick pulling out
Postby AE86less » Mon Mar 05, 2007 2:49 pm
I have to profess that i don't know anything about what the different rings and surclip looking things up the gearstick are supposed to do/look like, so bear with me if my description is a bit tedious. The gearbox is a k50 in my ae85.
Sometimes when i am driving, if i don't push down into the gbox while im changing gear, the gearstick pops out of its socket thing in the box.
I recently replaced the bushing thing that the stick sits on (that deteriorates and makes shifting sloppy), and when i did it the rubber cover that goes from the top of the box and covers all the washers and stuff on the stick split. I have also noticed that the metal plate on the top of the box that the stick goes through gets quite loose.
The two things i just listed are my guess at why it pops out. I also need to replace the stick because the little knob thing on the end of the ball has broken and the movement between gears is rediculous (I'm talking a throw distance of 30-40cm).
Will replacing the stick and the rubber thing fix the problem? (And does anyone have one they wanna sell me?)
Edit: Are sticks interchangable between boxes?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby AE86less » Tue Mar 06, 2007 11:45 am
Anyone? This sounds like a dumb q. but i really need an answer, the car has been green stickered so it's next WoF test is going to be really strict, it won't pass with the stick in this condition.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Ae92typeX » Tue Mar 06, 2007 12:56 pm
able to post any pic's up?
may be able to identify what/if something wrong via them.
Ae92typeX
Postby AE86less » Tue Mar 06, 2007 4:44 pm
I'll try and get some in the next few days, the car is at the panelbeaters getting some rust taken out of the door pillar. I should've thought of taking some before hand :evil:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
