EE100 Engine Swap
EE100 Engine Swap
Postby carlos3 » Mon Mar 05, 2007 10:18 pm
I have a 1992 NZ new 1300cc EE100 hatchback. The engine is rather tired, so the plan is to do a swap. Can I fit a 1600cc engine straight in, or is it a bit of a major? I had expected that the only difference between the 1300 and 1600 would be the stroke, but an engine supplier reckons they have different blocks etc??
Cheers,
carlos3
Postby Alex B » Mon Mar 05, 2007 10:24 pm
Yeah different block and different mounts. A GT starlet engine on the other hand, would bolt in.
Postby Ae92typeX » Mon Mar 05, 2007 10:26 pm
supplier correct, 1300 is an e series, 1600 (im assuming you mean 4age) a series. mounts need changing & if yours is a carby, need to change to injection tank also. could always fit a 1500cc 5e, but at the end of the day, it'd be better on the wallet selling and buying the bigger engine version.
Ae92typeX
Postby big_boy » Mon Mar 05, 2007 10:49 pm
assumeing its the same set up as a EE90 a 4AGE can be put in with off the shelf mounts or a 4E also a 7A can be put in (check with some one like BAZZA on mounts) or the 1800cc NZ new motor is ment to bolt in but never done this as i got board with that chassie & went to a MA61
for sale EE90
big_boy
Postby Alex B » Mon Mar 05, 2007 11:42 pm
The nz new 1800 is the 7a. I was under the impression the mount was quite a bit more forward on one of the motors??
Postby big_boy » Tue Mar 06, 2007 7:28 am
oh ok then i dident know the NZ new code but iv heard it can be done but i would be checking with some one whos done a 4A-7A swap before on mounts im thinking BAZZA`s probly best as we all know hes done that with good results
for sale EE90
big_boy
