error code 51
error code 51
Postby bluemaumau » Thu Mar 08, 2007 8:08 pm
4agze afm
51 Switch Signal
Diagnosis
* No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
* A/C switch circuit
* A/C switch
* A/C amplifier
* Throttle position sensor circuit
* ECU
ive got this twice now with 2 different ecus.
i just plugged in my new ecu and finnally got the idle down it was running fine. went to take off and the revs pick up and went to 3000rpm steady(maybe rising- i didnt want to find out)
wtf how can i be sweet for 15mins of tuning and then when you drive it, it $&#$% out?
ive removed ac so can i remove those from the above list?
thanks again :roll: :lol:
Postby bluemaumau » Thu Mar 08, 2007 8:26 pm
so
IDL = tps wire
A/C = aircon clutch
NSW = ?
Postby bluemaumau » Thu Mar 08, 2007 8:29 pm
NSW = Supercharger relay, Neutral switch 0r clutch switch
acoording to
http://www.club4ag.com/faq%20and%20tech ... 4A-GZE.htm
Neutral switch 0r clutch switch is this the clutch on the s/c or something on the throttle body/inlet?
Postby thaphatty » Thu Mar 08, 2007 9:44 pm
Neutral Switch? You didnt swap over to an automatic ecu or soemthing straight did you? like park inhibitor switch?
Clutch switch is found in many cars on the clutch pedal, same arrangement as a brake light switch, so car only starts when clutch is in. I doubt this is your problem.
Tried taking lid off ecu, looking for "NSW" on printed circuit board, looking at colour of wire tracing to supercharger? supercharger clutch wiring plugged in? continuity through to ecu?
someone bumped tps? tps wiring fine? tps bolts tight? IDL signal seems most likely to me. so then open ecu, find "IDL" wiring and make sure its not damaged/open circuiting?
thaphatty
Postby bluemaumau » Thu Mar 08, 2007 9:47 pm
i suppose that the neutral switch applys to autos.
nah the conversion was manual to manual
hmm ill have a look
Postby matt dunn » Thu Mar 08, 2007 9:47 pm
bluemaumau wrote:NSW = Supercharger relay, Neutral switch 0r clutch switch
acoording to
It's the neutral switch from the Auto Transmission.
Postby bluemaumau » Thu Mar 08, 2007 9:49 pm
haha i knew there wasnt any plugs bar reverse and speedo on the gbox, so it wasnt making sense,
so can i remove all those a/c faults as iv removed a/c?
Postby bluemaumau » Thu Mar 08, 2007 11:32 pm
im going to check the wire from ecu to tps tomorrow, see what happens
Postby blackmk3 » Fri Mar 09, 2007 1:02 pm
i had this problem just recently on my supra i was getting a code 51, i found that on the air conditioning pipe (high side) (the smaller diameter pipe) the one from the condensor at the front to the TX valve under the dash board theres a High pressure cutout switch the wires had broken off and were touching each other this was giving me the code, fixing this the code went away for about a day until i found that the TPS had died on me giving me another code 51, the TPS wiring was dodgy so i replaced the wiring and the TPS itself and problem sorted
Mk3 MA70 Supra
blackmk3
Postby bluemaumau » Fri Mar 09, 2007 4:51 pm
ok i just tested the line,
first of all can anyone confirm that the "IDL" line from the tps (blue with no stripes) is the same at the ecu plug?
if so i got continuity.
so i guess that means the wiring is sweet.
doing tps tomorrow
if your remove all teh a/c wiring (sip the lines at ecu and ac pump ends)
can you still get a/c fault codes?
