power window problem
Postby tsoob » Sat Mar 10, 2007 3:03 pm
i have a ae92 levin and it has this funny box that sits over the winder to make it a powerwindow and the bloody thing wont go down really annoying cos the car is black, it worked last week and now it wont go, any ideas>?
tsoob
Postby AE82 FXGT » Sat Mar 10, 2007 3:27 pm
Remove the box and put the original winder back on?
AE82 FXGT
Postby Ae92typeX » Sat Mar 10, 2007 3:42 pm
done anything electrical at all to the car since it last worked?
Played with anything that may have unplugged a connection (e.g. taking door cover off)?
checked all your fuses?
Ae92typeX
Postby tsoob » Sun Mar 11, 2007 4:22 pm
yeah dont have the winder other wise i would, no havnt touched anything except for a head light that was not going, i just pushed the plug on and it goes again????? its really frustrating to drive in the sun.
tsoob
Postby RS13 » Sun Mar 11, 2007 5:43 pm
Lol, I had the same problem, but I have a 4door, so my fix may not be the same as yours.. I removed the panel, unplugged the plug from SWITCH to MOTOR, hooked up a multimeter and flicked the switch. 11.85V.. so swapped the rear door motor over with the front, problem solved! :) However, you'll need an operating window for a wof, so its' only a temporary fix.
RS13
Postby Ae92typeX » Sun Mar 11, 2007 6:46 pm
RS13 wrote:... However, you'll need an operating window for a wof, so its' only a temporary fix.
you sure windows need to open for wof? never seen them test them ever, and cant see a reference to it on the vir manual
but yeah, a non working front window is a bastard. whip it out and test with a multimeter, or just go to the wreckers and grab a winder if you can indeed just put a manual winder on.
Ae92typeX
Postby tsoob » Tue Mar 13, 2007 10:41 pm
yeah thanks i think ill go for a winder (multigrips) for now.
tsoob
