gasman wrote:well i would like to run aftermarket rods and pistons for the just in case factor but if i cant gather up enough cash then ill just go with the gze rods and pistons.
if i did run the gze pistons would i need to get the valve pockets cut or just leave it.
how much for gze rods and pistons new from toyota anyone know?
not preping exclusively for track just aiming for over 200kw. what can be done to the oil system other than going with a dry sump?
gasman wrote:i emailed acl performance about their 20v forged pistons with 8.5:1 ratio
http://www.aclperformance.com.au/Toyota ... istons.htm
RedMist wrote:gasman wrote:i emailed acl performance about their 20v forged pistons with 8.5:1 ratio
Am I going blind... or do those pistons have a massive skirt!
gasman wrote:from what i can gather 440cc injectors would be good for approx 200kw on standard fuel pressure so how much more could i get out if it if i get a FPR to up the pressure.
how about running an extra injector?
matt dunn wrote:RedMist wrote:gasman wrote:i emailed acl performance about their 20v forged pistons with 8.5:1 ratio
The picture is stretched,
Click on the picture to enlarge it and it comes right.
IH8TEC wrote:oil system you can shim the oil pump so it creates more pressure, absolutely no need to dry sump it.
RedMist wrote:
Still looks like a big skirt for a racing piston. Could still be skewed, as the deck height looks massive as well.
gasman wrote:so how hard is it to put a bare engine block and parts back together? cant be too hard can it?
Santa'sBoostinSleigh wrote:gasman wrote:so how hard is it to put a bare engine block and parts back together? cant be too hard can it?
*generally* if you have to ask something like that, then its not a good idea to attempt it yourself
if youre going to all the trouble of using flashy parts, and turboing an N/A engine, dont combine it with the 'she'll be right mate' attitude or else youre likely to end up with a worthless lump of used-to-be-an-expensive-engine
