How to make ST205 WRC antilag work.... the RedMist way
Postby RedMist » Sat Mar 31, 2007 8:03 pm
Take one WRC antilag actuator.
Ample frustration at not being able to make the bloody valve move.
Take one flat punch
and one big hammer.
Simmer gently for about 1.5 hours of head scratching then take the punch (I do suggest you use something more fitting to distribute the load) and with a generous helping of hammer take to the valve face.
You'll end up snapping the spot weld in the center of the valve holding it to the brace running through the center of the exhaust port.... and now you have a functioning antilag actuator... what you'll do with it considering you dont have a trigger, I dont know.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Sun Apr 01, 2007 3:15 pm
yeah i find beating the crap out of stuff very theriputic.
so have you figured out how to make a link run it?
Postby Prymal » Mon Apr 02, 2007 6:57 pm
and have you found a way for it to run without destroying the turbo and such ??
you could use an aftemarket ECU it activate it , but yeah , how often do you want to rebuild your turbo ??
Prymal
Postby IH8TEC » Mon Apr 02, 2007 8:14 pm
classique71 wrote:and have you found a way for it to run without destroying the turbo and such ??
he has a new link, and anti-lag will always destroy a turbo, just a matter of how fast
Postby RedMist » Mon Apr 02, 2007 8:52 pm
Snap.
RedMist
Postby RedMist » Thu Apr 05, 2007 8:51 am
Mr Revhead wrote:yeah i find beating the crap out of stuff very theriputic.
I unfortunatley dont have any of the VSV's or plumbing for it.... however using a GP output on the Link based on MAP and an antilag switch should work... possibly... but certainly needs a play.
RedMist
Postby mister2 » Sun Apr 08, 2007 8:19 pm
Hey, it will be entertaining anyway, right? :D
Nothing like a bit of pop-pop-bang-bang.
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby RedMist » Sun Apr 08, 2007 9:20 pm
mister2 wrote:Hey, it will be entertaining anyway, right? :D
Its almost becoming critical. How do you get a road worthy car sound like a rally monster anymore?
Noise regulated for WOF....
Recirc blowoff....
36mm intake restrictor....
Old school bang bang is a must!!!!
At the very least it'll keep me awake at the wheel.
I'll trust you Nick, to make my "fat cat" both sound and react like the rally monster its supposed to be.
RedMist
Postby mister2 » Mon Apr 09, 2007 2:35 pm
Heh. From my sig: "On hiatus, current location: Los Angeles, USA"
But Walter or Phil should be able to sort you out.
www.nzefi.com
mister2
Postby RedMist » Mon Apr 09, 2007 5:23 pm
Its probably 3-4 weeks away from being able to be tuned.... thought you were off to the great UK..... for a very extended period?
RedMist
