Battery Wire.
Battery Wire.
Postby Silent Knight » Wed Apr 04, 2007 9:11 am
I need some 0ga wire for the new battery I'm mounting in the boot. As I know very little about what kind of wires etc to use I thought I might post up on here for those in the 'know' when it comes to electrical stuff.
I am currently consider some of the 25/35mm Welding Flex Wire that BOC has for sale. Would that be suitable for what I want to do or do I need a different brand or type of wire for the jobbie?
Part number from BOC is WC25 or WC35.
It should be on their site if you go in to the webshop. Sorry I don't have the URL handy as it's all dynamic stuff so won't work if I copy/paste it.
I remember Wayne mentioning something about thin strand as well?
If this is the right stuff I don't suppose anyone here works for BOC? :P
Silent Knight
Postby thegreatestben » Wed Apr 04, 2007 10:13 am
SW20's have a big thick battery cable that is pretty long. Might be too short for a larger car though.
thegreatestben
Postby Rob_GTZ » Wed Apr 04, 2007 12:35 pm
Welding wire is good stuff, High current capacity, & great for going around corners. It does require a tool to crimp it correctly, but talk to the retailer, as more often than not you can borrow or rent this from them.
Rob_GTZ
Postby Jazza » Wed Apr 04, 2007 12:42 pm
Think i might have the crimper downstairs in my garage somewhere hanre, if you need one let me know and ill see if i can find it
1996 Curren - On Tardme
Jazza
Postby DeeCee » Wed Apr 04, 2007 3:16 pm
here you go - my battery relocation tutorial..
http://forums.sqnz.co.nz/viewtopic.php?t=271
GT Four Adovansu
DeeCee
Postby Silent Knight » Wed Apr 04, 2007 3:44 pm
Need to be logged in to view. :cry:
Silent Knight
Postby fivebob » Wed Apr 04, 2007 4:09 pm
Anyone tried the Projecta single or double core wire? Looks like it's designed for the job.
http://www.projecta.com.au/catalogue/cid/53/asset_id/91
Postby Silent Knight » Wed Apr 04, 2007 4:23 pm
Excellent, they have an office in NZ.
What would you recommend out of the wires they have available there fivebob? I am useless when it comes to wires/electrical stuff.
Silent Knight
Postby DeeCee » Wed Apr 04, 2007 4:36 pm
Silent Knight wrote:Need to be logged in to view. :cry:
i'm sure that you'll sign up and get over yourself.. :P
GT Four Adovansu
DeeCee
Postby fivebob » Wed Apr 04, 2007 5:14 pm
Silent Knight wrote:Excellent, they have an office in NZ.
Not sure what you requirements are. 25-35mm should be enough, but it all depends on the current draw and the distance. Obviously thicker cable will give you a lower voltage drop and greater current carrying capacity.
BTW I just did some more checking and found that this cable is manufactured by Brown and Watson and also sold under the Narva brand, and the double core stuff is also sold as welding cable ;)
Postby Silent Knight » Wed Apr 04, 2007 8:41 pm
Thanks fivebob, I'll see if I contact that place tomorrow and get some wire. I'll probably go for the 35mm double core stuff as I suspect that will be allot better quality.
Silent Knight
Postby vvega » Wed Apr 04, 2007 9:31 pm
unless you go oxy free most fine stranded cable with be of equal quality
personally i go for teh double isulated
just cause i like teh exra safe feeling
it only takes a few seconds for a short to make a cable fill yoru cabin with smoke..........in fact its almost instant :d
v
vvega
Postby Caveman » Wed Apr 04, 2007 10:01 pm
sup hanre
I use 50mm welding wire from BOC at $10/m. Double insulation.
then a 120amp circuit breaker at teh battery
circuit breaker starts 4AGE no problems, may need bigger if this is going on your jz motor, circuit breaker from jaycar
I used custom crimps that I made from copper pipe, basically bend one side of the copper pipe flat, drill a hole in it, stick the wire in the end still round, and close it up with a hammer and chisle 8) works really well
have done this on all my cars, no problems
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Adydas » Wed Apr 04, 2007 10:34 pm
If you want wire let me know i can get it dam cheap..
Any guage and size you want, cut to order styles.
Adydas
Postby themaleman » Thu Apr 05, 2007 12:13 am
i used double insulated 50mm stuff, hasd 2 buy a bit of 35mm wire (biggest the store had) which costed round $25 a metre!! im using the standard fuses 2
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Mike- » Thu Apr 05, 2007 8:56 am
go to ja russell or ideal electrical and talk to them, probably cheaper and theyll know what theyre talking about
Mike-
Postby DeeCee » Thu Apr 05, 2007 9:36 am
get lugs from places like ja russell / ideal electrical / electrical wholesaler.
Get them to crimp them as well as they will normally do it for free and you get a perfect hex crimp..
GT Four Adovansu
DeeCee
Postby Silent Knight » Thu Apr 05, 2007 11:46 am
Cliff can you get me a price on some good quality 35-50mm double insulated fine strand wire? I need 6m worth.
Silent Knight
Postby postfach » Thu Apr 05, 2007 1:54 pm
I used 25mm² welding cable and its perfectly fine. i don't have a stereo but i'm sure it would be perfectly capable since we run huge LED screens with it drawing hundreds of amps at 48V. pm me if you want some, i can get 10m of it for you free of charge and lend you the crimping tool.
postfach
Postby Silent Knight » Thu Apr 05, 2007 2:15 pm
ooooH that sounds very interesting.
I'd be game on a bit of that action if you can hook a brother up. 8)
Silent Knight
