Stealer Of Souls wrote:Why are the majority of turbos (that I've seen) not on a nice set of tuned length extractors? Is there a technical reason? Or just a physical construction/space issues?
Im sure redmist or similar can enlighten us with good fluid knowledge
Stealer Of Souls wrote:I'm sure there's a reasonably good reason...
But.
Mr Revhead wrote:Im sure redmist or similar can enlighten us with good fluid knowledge
his knowledge of cheap wine and its effects on ppl of dubious reputatuon arnt really applicable to this thread.....
how ever his knowledge of heimholtz may well be
Bazda wrote:I was reading a book on the V8 super cars in aussy, found it quite interesting.
They said that equal length pipes wont gain you horsepower, it will just move the power band around. They dont run equal length extractors they purposly make them un even in some scientific way to get what power band they want.
strx7 wrote:its all about............area below the curve.............
longer extractor type set up will hand it to a short factory manifold even a 3SGTE in this area EVERY time
RedMist wrote:Helmholtz when it comes to turbos.. I am screwed. It a bloody complex subject on a NA basis. Add a variable compressed charge and a backpressure wave from the turbo and your adding a complexity I've never attempted to unravel.
fivebob wrote:strx7 wrote:its all about............area below the curve.............
Got any PROOF of that, all my texts say that tuned length is nowhere near as important on a turbo engine.
. What's good for a NA engine is not necessarily correct for a turbo. NA pipe design is all about scavenging the system, turbos are about energy delivery. A blanket statement that longer is better is just as bad as saying the short headers are the way to go for a turbo engine. It all depends on what the correct tuned length is for the engine. The other factor to consider with turbo engines is how the pulses hit the turbine and how much energy they impart to the blades.
You're not the only one, I remember reading in one of Prof. Gordon Blair's books that he spent two years trying to analyse, or even find evidence of, return waves through turbo systems. So if he has problems, what hope is there for mere mortals
Users browsing this forum: Bing [Bot] and 4 guests
