Turbos and extractors
Postby Stealer Of Souls » Thu Apr 12, 2007 6:10 pm
I'm sure there's a reasonably good reason...
But.
Why are the majority of turbos (that I've seen) not on a nice set of tuned length extractors? Is there a technical reason? Or just a physical construction/space issues?
I mean if there's sufficient space available, would a half way decent extractor design improve power development (probably at the expense of spool time).
'86 AE85.5 Levin
Stealer Of Souls
Postby Caveman » Thu Apr 12, 2007 8:31 pm
Are you talking about standard manifolds, because the answer is usually cost and space
with custom made, I always make even length, and so does pretty much everyone else. Only cheap arse people dont :lol:
AW11 Track Toy
Formerly known as 1998
Caveman
Re: Turbos and extractors
Postby strx7 » Thu Apr 12, 2007 10:18 pm
Stealer Of Souls wrote:Why are the majority of turbos (that I've seen) not on a nice set of tuned length extractors? Is there a technical reason? Or just a physical construction/space issues?
The MAIN reason is because no one really sells them as an 'off the shelf' item, and thats what MOST people use in their cars.
Anyone who goes to the effort of making a new exhuast manifold for their turbo application usually goes some way to making it equal length, unless they are one of the goons who still believes that having the turbo as close as possible to the exhuast port gives the best results (which it certainly does not.
on road cars, space is also a big consideration.
Postby Stealer Of Souls » Fri Apr 13, 2007 10:25 am
Caveman: Yeah... Aftermarket/custom sets. Not factory as we know they are all cheap beggars...
Even so. The manifolds may be even length, but they all seem very short. Where as NA extractors are very long.
Now I understand that space restrictions mean that you can't have a set that is uber long, but most s-e-e-m to have very short lengths.
Wouldn't having the extractor design as long as possible be better?
Also is there a difference between 4-1 and 4-2-1 designs on a turbo engine?
'86 AE85.5 Levin
Stealer Of Souls
Postby Caveman » Fri Apr 13, 2007 11:06 am
Not sure on the correlation between length and power
however having even lengths gives even pressures in each cylinder, catches each cyclinder pulse better, etc, etc. A good collector is another thing I fail to see on a lot of manifolds, and I would consider it to make a significant difference in power.
Looking at that 8 second evo docile, and the mirage replica, they have very long manifold runners before the turbo, and a beautiful collector.
Im sure redmist or similar can enlighten us with good fluids knowledge 8)
edit: ment fluids lol thx revhead
AW11 Track Toy
Caveman
Postby Mr Revhead » Fri Apr 13, 2007 11:49 am
Im sure redmist or similar can enlighten us with good fluid knowledge
his knowledge of cheap wine and its effects on ppl of dubious reputatuon arnt really applicable to this thread.....
how ever his knowledge of heimholtz may well be
Postby strx7 » Fri Apr 13, 2007 2:18 pm
ala
Postby Al » Fri Apr 13, 2007 2:20 pm
Stealer Of Souls wrote:I'm sure there's a reasonably good reason...
But.
Some engines like the 3sgte don't show worthwhile gains for the cost with fancy manifolds over an adaptor attached to the stock manifold.
Al
Postby strx7 » Fri Apr 13, 2007 3:18 pm
its all about............area below the curve.............
longer extractor type set up will hand it to a short factory manifold even a 3SGTE in this area EVERY time
Postby Stealer Of Souls » Fri Apr 13, 2007 7:29 pm
So it's really just packaging then... Lack of space/cheap ass beggars!
'86 AE85.5 Levin
Stealer Of Souls
Postby RedMist » Fri Apr 13, 2007 8:19 pm
Cheap wine... I'm your goat lover.
Helmholtz when it comes to turbos.. I am screwed. It a bloody complex subject on a NA basis. Add a variable compressed charge and a backpressure wave from the turbo and your adding a complexity I've never attempted to unravel. One thing that is certain, Caveman is so very correct in his asssement of collectors. For some reason on turbo charged machines I've seen... they are all disgusting, stock or otherwise. I'd love to put a nice split interferance collector on my 3SGTE.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Bazda » Sat Apr 14, 2007 12:57 am
I was reading a book on the V8 super cars in aussy, found it quite interesting.
They said that equal length pipes wont gain you horsepower, it will just move the power band around. They dont run equal length extractors they purposly make them un even in some scientific way to get what power band they want.
Postby RedMist » Sat Apr 14, 2007 8:30 am
Bazda wrote:I was reading a book on the V8 super cars in aussy, found it quite interesting.
Equal length pipes can give you HP.... sortof. All pipes have a natural Helmholtz frequency that frequency can be related to an RPM. If that associated RPM is too high like 10,000 RPM or too low 1000 RPM then altering the length (we can be talking about a 1/4 inch here!) will bring the frequency back to a more useable RPM.
What the V8 boys are doing... with many more cylinders than you and I... are creating multiple Helmholtz frequencies. What they are attempting to do is actually create multiple bursts in power to broaden the torque curve. But believe you me, they complete a tonne of fluid dynamics calcs and match the pipes for optimal power over the spread of RPM required.
The V8's could run equal length pipes (if they can get around that silly firing order) and have a huge spike in HP one RPM... but it would be considerably slower on the track. At the end of the day its all about the area under the HP curve that falls within your working RPM.
I suspect that with some very good collectors (I like split interferance) and a tonne of RPM a 4-2-1 system with two different lengths, for a 4 cyl might actually work. If the friction doesnt take it down first. ;)
RedMist
Postby fivebob » Sun Apr 15, 2007 1:30 am
strx7 wrote:its all about............area below the curve.............
Got any PROOF of that, all my texts say that tuned length is nowhere near as important on a turbo engine.
. What's good for a NA engine is not necessarily correct for a turbo. NA pipe design is all about scavenging the system, turbos are about energy delivery. A blanket statement that longer is better is just as bad as saying the short headers are the way to go for a turbo engine. It all depends on what the correct tuned length is for the engine. The other factor to consider with turbo engines is how the pulses hit the turbine and how much energy they impart to the blades.
Postby fivebob » Sun Apr 15, 2007 1:33 am
RedMist wrote:Helmholtz when it comes to turbos.. I am screwed. It a bloody complex subject on a NA basis. Add a variable compressed charge and a backpressure wave from the turbo and your adding a complexity I've never attempted to unravel.
You're not the only one, I remember reading in one of Prof. Gordon Blair's books that he spent two years trying to analyse, or even find evidence of, return waves through turbo systems. So if he has problems, what hope is there for mere mortals :?
Postby RedMist » Sun Apr 15, 2007 3:02 pm
I'd also be curious in regards to any proof. Ignoring Helmholtz, I would have thought completely the opposite to be true. Keep it short, exhaust temp up, keep the charge velocity up, keep the turbo spinning.
In regards to NA Helmholtz, because you are often halving / third / quartering the frequency (otherwise the manifold becomes stupidly long) changing a manifold by as much as a 1/4 inch could change the optimal frequency by massive amounts. Shorting a manifold can give you more mid or low end if you go from a third frequency to double. Similarly lengthening a manifold can give you more top end.
The mathematics are involved and are fully dependant on a tonne of variables including cam timing. Sometimes, budget allowing, its better use the mathematics to provide a close enough estimate and then run multiple dyno runs altering lenghts until the optimal is found....
... my expansive budget has me using the stock ST205 WRC manifold. And its uuuuugly.
RedMist
Postby mister2 » Sun Apr 15, 2007 4:27 pm
That man does know his unsteady flow alright. Writes fantastically readable texts though.
The real world examples that I've seen seem to indicate that the most important part of a turbo manifold is the collector.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Mr Revhead » Sun Apr 15, 2007 9:43 pm
so maybe the improvements seen in the above mentioned post that strx7 is referring to were made by a less conflictive flow rather than any scavaging effect?
i can see how a aftermarket manifold would flow better than some stock ones iv seen.
Postby Stealer Of Souls » Sun Apr 15, 2007 10:57 pm
Hmmm.
Okay. A turbo would add another level (or three) of complexity to the equations. But one would normally think that a NA type scavenging design would also be good for a turbo.
It would however by the same thinking, it would make the turbo spool slower, and possibly lose response.
'86 AE85.5 Levin
Stealer Of Souls
