noisy silvertop..
noisy silvertop..
Postby EVL20V » Mon Apr 16, 2007 9:09 pm
ok, so the 20v silvertop blows plenty of smoke when you floor it.
but at idle it sounds like a diesel :lol: not your normal ticking like an rb20 or b16a, but this is more chronic, and quite frankly you would need to unbolt the exhaust to drown out the sound :lol:
oil level is sweet, compression is sweet, no knocking or anything.
any suggestions? cheers
EVL20V
Postby TRD_ZERO » Mon Apr 16, 2007 9:42 pm
What colour smoke?
TRD_ZERO
Postby EVL20V » Mon Apr 16, 2007 9:48 pm
black/blue, so basicly rings had it, but maybe steam seals?
EVL20V
Postby bluemaumau » Tue Apr 17, 2007 12:18 am
is it facelift ? sergei has explained a few times about how the injectors vary, have a search
edit:http://forums.toyspeed.org.nz/viewtopic.php?t=56311&start=0
Postby JRS » Tue Apr 17, 2007 6:14 am
could be the infamous VVT cam gear rattle.
meh.....
JRS
Postby trueno_20v » Tue Apr 17, 2007 4:25 pm
same as what mine done , vvt pulley.
ADMIN EDIT: signature too large
trueno_20v
Postby Levin » Thu Apr 19, 2007 11:52 pm
I used to have an AE101 Levin, and mine too rattled like crazy. Apparently it was because the shims were quite worn. Like yours it smoked a bit under hard acceleration, but the compression was fine, and so was the oil. If your problem is with the shims too then its just an annoying noise, nothing to worry about. BTW mine had done about 220ks
Levin
