lsd or not?
lsd or not?
Postby drtydog » Wed Apr 18, 2007 10:40 pm
hey quick question, which model sw20 mr2 came out with lsd, and how do u tell if u got lsd or not?
drtydog
Postby FST4RD » Wed Apr 18, 2007 10:53 pm
Put foot on clutch and then into 1st, rev the motor to all buggery and then drop the clutch, then go back and inspect whether or not you left one or 2 marks behind :lol:
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby MR2SIK » Wed Apr 18, 2007 10:57 pm
FST4RD wrote:Put foot on clutch and then into 1st, rev the motor to all buggery and then drop the clutch, then go back and inspect whether or not you left one or 2 marks behind :lol:
:P I was about to say the same thing lol
put one wheel on grass and one wheel on concrete, do what fst4rd says, if theres 2 marks then you most likely have a lsd...
my build plate states i have an open dif, various tyre marks say otherwise :twisted: fst4rd may know the history of my gearbox better than me :lol:
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Dell'Orto » Wed Apr 18, 2007 10:59 pm
A. this ought to be in tech and B. search, it has been covered.
Dropping the clutch on tarmac in an SW20 can leave two black lines even with an open diff, I know mine did. One wheel on grass will spin though
Postby FST4RD » Wed Apr 18, 2007 11:01 pm
The gearbox in my old mr2 now MR2SIK's MR2 is awesome!!!! I used to have some real fun with the LSD in it, but after some of the stuff found in the car (various computers, suspention, gearbox) i wouldn't be surprised if someone in japan has had it as a street/track racer.....
FST4RD
Postby MR2SIK » Wed Apr 18, 2007 11:05 pm
still never figured out what that toms chip thing did :lol:
what did you find with the suspension? i noticed it was a little lower than stock.... Dont want to go changing anything that doesnt need it :twisted:
MR2SIK
Postby drtydog » Wed Apr 18, 2007 11:22 pm
well i did do a search but couldn;t find nething...
clutch is a bit buggered so can;t leave nice tyre marks on the tarmac...til i get a new one neway ;)
i do know it does mean as donuts on gravel lol...i guess doing it on gravel would leave one if open 2 if lsd?
also, did sw20 have adjustable damper rates on the suspention from factory?
drtydog
Postby Bling » Wed Apr 18, 2007 11:28 pm
gravel is a different kettle of fish as theres not much force to stop both spinning if yours is in fact open.
do as said above, pull half off the road somewhere, you don't have to rev it too much, but if you let the clutch out fast enough you shouldn't move if its open diff as the wheel on the grass should spin freely whereas the wheel on the road shouldn't. if it takes off tho, then it could be LSD or you need to rev it more and retry :lol:
Postby drtydog » Wed Apr 18, 2007 11:36 pm
cool i'll giv it a go sum time lol
drtydog
Postby fivebob » Wed Apr 18, 2007 11:54 pm
All SW20 turbos produced after 12/91 (Chassis # >= 059266) came out standard with LSD.
Postby drtydog » Thu Apr 19, 2007 12:22 am
ok i'll chek that mines a 92
drtydog
Postby vvega » Thu Apr 19, 2007 12:32 am
my aw will spin both wheels if you use the throttle with enought anger
gras is good
you dont need to drop the clutch simply let clutch out and put foot down....
v
vvega
Postby vvega » Thu Apr 19, 2007 12:33 am
fivebob wrote:All SW20 turbos produced after 12/91 (Chassis # >= 059266) came out standard with LSD.
can you call that viscous thing a lsd :d
vvega
Postby drtydog » Thu Apr 19, 2007 1:06 am
hmm mines not turbo tho...i'm guessing it's just an open diff sure gets sideways easy with a bit of accelerator tho
drtydog
Postby drtydog » Thu Apr 19, 2007 5:46 pm
well gng by ur lil test it has an lsd lol...i did suspet wasn;t certain tho :)
drtydog
