postfach wrote:here
http://gtfour.supras.org.nz/diagrams.htm
*84vvt* wrote:Have you had a look in side
the case?
pop the lid off the ecu
Toyota some times prints the
pin functions on the
circuit board
if you have the harness
all you need to know is were
the Batt batt+ start etc
wires go
hope this helps
Block Pin Assignment Description Wire Colour
A 1 #10 Injector #1 Black -
A 2 #20 Injector #2 Black-White -
A 3 #30 Injector #3 Green-Yellow -
A 4 #40 Injector #4 Black-Yellow -
A 5 (SLT-) (?) Brown-White - -
A 6 (SLT+) (?) Green-White - -
A 7 (SL1-) (?) Light Green - -
A 8 (SL2+) (?) Pink-Black - -
A 9 (SL1+) (?) Violet - -
A 10 IGT1 Ignitor #1 Yellow-Black
A 11 IGT2 Ignitor #2 Red-Blue
A 12 IGT3 Ignitor #3 Blue-White
A 13 IGT4 Ignitor #4 White-Blue
A 14 (NC+) (?) Blue - -
A 15 (NT-) (?) Red - -
A 16 (NT+) (?) Black - -
A 17 - Not Used
A 18 RSO Idle Speed Control Black -
A 19 (DSL) (?) Blue-Red - -
A 20 (SL2-) (?) Light Green-Red - -
A 21 EO1 Earth (Engine) Brown -
A 22 FPU Fuel Pressure VSV Pink -
A 23 - Not Used
A 24 - Not Used
A 25 - Not Used
A 26 (NC-) (?) Green -
A 27 KNK Knock Detector White Shielded
A 28 CF/FAN Cooling Fan Blue-Red -
A 29 (S4) (?) Red-White - -
A 30 - Not Used
A 31 EO2 Earth (Engine) Brown -
B 1 - Not Used
B 2 VC +5v Light Green-Red
B 3 HT Oxygen Sensor Heater Black-Yellow
B 4 PRG Evap Purge valve Black-Orange -
B 5 - Not Used
B 6 SPC Turbo VSV Blue-Black -
B 7 FPR Fuel Pump Relay Black-Red -
B 8 STA Start Black-White - -
B 9 ION1 Ignitor #1 Signal Return Yellow
B 10 ION2 Ignitor #2 Signal Return Yellow-Black
B 11 PIM Manifold Pressure Green-Black
B 12 OX1 Oxygen Sensor Black
B 13 (THO) Transaxle Oil Temp Orange - -
B 14 THW Engine Water Temperature White -
B 15 G2+ Cam Position Sensor Black-White
B 16 NE+ Crankshaft Position Sensor Black-White
B 17 E1 Earth Brown -
B 18 E2 Earth Brown -
B 19 ION3 Ignitor #3 Signal return Yellow-Green
B 20 ION4 Ignitor #4 Signal return Yellow-Red
B 21 - Not Used
B 22 THA Intake Air temp Red-Blue -
B 23 VTA Throttle Position Light Green
B 24 NE- Cam/Crank Position Sensor Earth Blue
C 1 (D) Drive Light Green-Black -
C 2 (R) Reverse Red-Black -
C 3 (2) 2 Light Green-Red - -
C 4 - Not Used
C 5 TC Check Connector (12v) Pink-Black - -
C 6 (STP) Stop Light Green-White -
C 7 (2LP) (?) Red - -
C 8 (1LP) (?) Green-White - -
C 9 (0LP) (?) Violet - -
C 10 (OD2) (?) Black - -
C 11 - Not Used
C 12 (L) Shift Lever in L position Light Green - -
C 13 ACT Air Conditioning ? Light Green-Black - -
C 14 THWO Water Temp Output? Yellow-Red - -
C 15 - Not Used
C 16 (SPTL) (?) Orange - -
C 17 BPC+ Variable exhaust motor + Pink -
C 18 (SPT) Manual Shift Mode Switch Red-Black - -
C 19 (THOL) Transmission Oil Overheat Orange-Yellow -
C 20 NSW Neutral Start Switch Black-White - -
C 21 - Not Used
C 22 SPD Speed Violet - -
C 23 - Not Used
C 24 - Not Used
C 25 AC Air Conditioning Demand Yellow-Green - -
C 26 BPC- Variable exhaust motor - Brown -
C 27 TACH Tachometer Black - -
C 28 - Not Used
D 1 BATT Battery + Black-Yellow -
D 2 - Not Used
D 3 FC Circuit Opening Relay Green-Red - -
D 4 (DLP) Shift Lever in Drive Light Green-Black -
D 5 - Not Used
D 6 W Warning Red-Yellow - -
D 7 PSW Power Steering Pressure Switch Green-Yellow -
D 8 - Not Used
D 9 (SFTU) Shift Switch Up Pink - -
D 10 THAM Intake manifold Temperature Green -
D 11 SIL Check Connector (Signal) White - -
D 12 - Not Used
D 13 EFI- TRC/ABS White - -
D 14 EFI+ TRC/ABS Red - -
D 15 NEO TRC/ABS Black-Orange - -
D 16 IG+/+B Igniton (12v) Black-Red -
D 17 (SFTD) Shift Switch Down Blue-Red - -
D 18 TRC- TRC/ABS Blue - -
D 19 ELS Rear Window Demister Green-Yellow - -
D 20 (MLP) (?) Green-White - -
D 21 TRC+ TRC/ABS Light Green - -
D 22 (RJT) (?) Yellow-Red - -
fivebob wrote:You don't want much do you![]()
I might have all this information, but before I waste my time looking for it, could you please tell me how you're going to run a Plug & Play system with an Auto?
How are you going to control the Transmission functions? A Nemesis ECU sure won't do it as far as I can tell.
CaldinaGt_t wrote:fivebob wrote:You don't want much do you![]()
i just realized that it wont control the transmssion functions, but i would like the information same way so i can get one built for the manual car and just convert to gearbox.
TWSTD wrote:I have the info you need - you need to buy the book to get it though!
See my post here:
viewtopic.php?t=55014&highlight=
