fuel mixture screw - k series carbs
Postby scope » Mon May 14, 2007 8:07 am
hey
just wondering if anyone knows how to set it back to the factory setting? screw it all the way in then out a few times? how many is a few in that case?
thanks
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Dell'Orto » Mon May 14, 2007 6:33 pm
1 1/2 from memory I think, will check later on
Postby matt dunn » Mon May 14, 2007 9:50 pm
You realise that is only idle mixture?
Postby scope » Mon May 14, 2007 10:06 pm
yup
it's shit when it's idling that's why i ask :lol:
mmm, boost said it might be an air leak though (the idle jumps up and down 100rpm and is backfiring a little bit)
that's at 1000rpm, if i turn it down to 800rpm it jumps around even more
scope
Postby Crucible » Mon May 14, 2007 10:18 pm
acetylene or ethor are good for finding vacuum leaks. If you partially choke it with your hand and the revs even out, is normally a good sign a vac leak is present.
you can set idle mixtures with a vac gauge, screw right in and turn out until it wont pull any more vacuum or the revs dont improve further, but 1 1/2 turns out is normally ok as a base setting.
Crucible
Real Life Mechanic
Postby 79rolla » Mon May 14, 2007 10:28 pm
just get it tuned proply man lol
past: AE82 FXGT
79rolla
Postby scope » Tue May 15, 2007 8:25 am
79rolla wrote:just get it tuned proply man lol
that means $$ and that's not much of a learning experience is it!
scope
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
