Toyota 1990 MR2
Toyota 1990 MR2
Postby Rasker » Tue May 15, 2007 12:03 pm
Hi Folks,
What would the factory spec be for the hand brake to engage? 3 or 5 clicks?
My little beast keeps failing on the hand brake, and is adjusted each time back to 3 clicks, and 6 months later I'm stung with another adjustment.
- Scottie
Rasker
Postby Paschendale » Tue May 15, 2007 4:18 pm
SW20 Mr2's are proned to stretch/snap handbrake cables, so you might want to take that into account
Paschendale
Postby strx7 » Tue May 15, 2007 5:10 pm
Paschendale wrote:SW20 Mr2's are proned to stretch/snap handbrake cables,
AMEN
Postby Alex B » Tue May 15, 2007 6:21 pm
Which one/ones usually stretch? Just the main one or the two going to the wheels too?
Postby Mr Revhead » Tue May 15, 2007 9:36 pm
all of them!
usually the two long ones
so if one long one fails..... do both.
and i have had ppl disagree with me.. one of which soon after ordered a new bumper off me......
Postby Rasker » Tue May 15, 2007 9:50 pm
What about looking at a hydraulic handbrake solution? Is it doable on a MR2 and still road legal?
There has to be a better way then pulling half the car apart to change these cables.
Rasker
Postby Rasker » Tue May 15, 2007 9:55 pm
*sigh* worse case what am I looking at for the cables? I got a quote of over 1k to replace just the front cable, which sounds a little over the top to me.
Rasker
Postby Alex B » Tue May 15, 2007 9:57 pm
Feck off, last quote i got was like 80 bucks a cable.
Postby Rasker » Tue May 15, 2007 10:00 pm
The 1K price was for mostly the labour involved, I can't get my head around that bit.
Rasker
Postby Mr Revhead » Tue May 15, 2007 10:34 pm
are you sure you havnt added a 0 to that?!
while its not as simple as other cars, it shouldnt be even close to a grand
Postby Rasker » Tue May 15, 2007 10:39 pm
Ilam Toyota in CHCH reckons it was going to take removing the gas tank, the coolant piping and half a dozen other things just to replace the front cable hence the 1K figure, and that's before they start on the rear cables 8O
Rasker
Postby Mr Revhead » Tue May 15, 2007 10:42 pm
yes you have to drop the tank
but thats not a huge job....
Postby Rasker » Tue May 15, 2007 10:43 pm
Then I ponder how they got to the figure of a K just to do the front cable?? That's nuts that's the sort of price that makes people want to flick the car off.
Rasker
Postby tex » Tue May 15, 2007 11:28 pm
You don't have to drop the tank to replace the front. You can get to it without dropping the tank. Well i have anyway.
TEX
tex
Postby Alex B » Tue May 15, 2007 11:36 pm
Dropping the tank would involve dropping the water lines yes? Which would be a complete c**t.
Postby solitaire » Tue May 15, 2007 11:41 pm
tex wrote:You don't have to drop the tank to replace the front. You can get to it without dropping the tank. Well i have anyway.
TEX
2nd'd, bought a cable from Revhead and did it by only taking off the plastic under covers... i ended up taking the seat out to get at the handbrake itself though....
AE92, KZJ120, KDJ120
solitaire
Postby lucasthefallen » Wed May 16, 2007 8:27 pm
the coolent lines are easy to remove, very easy. the biggest PINA about it all is bleeding the cooling system again and drop fuel from the tank, but if you do it when your nearly out of gas it'll be sweet. anyone with a basic set of tools, jack and stands, and a can-do attidude is more then capable of doing it themselves.
Need Service or Repair work done? send me a PM
lucasthefallen
Postby avinesh » Wed May 16, 2007 9:24 pm
lucasthefallen wrote:the coolent lines are easy to remove, very easy. the biggest PINA about it all is bleeding the cooling system again and drop fuel from the tank, but if you do it when your nearly out of gas it'll be sweet. anyone with a basic set of tools, jack and stands, and a can-do attidude is more then capable of doing it themselves.
why do u have to drop the fuel tank i went under the car an you only remove the plastic cover an there it is the hand brake cables....
avinesh
Postby Ae92typeX » Wed May 16, 2007 11:03 pm
go somewhere else if you cant do yourself. I wouldnt say it has to be a 'toyota specalist' for a handbrake cable.
going hydraulic would cost you more and involve more labour. Never tried to road cert one, but Ive known of others with different cars.
Ae92typeX
Postby Bling » Thu May 17, 2007 12:24 am
Rasker wrote:Ilam Toyota in CHCH reckons...stuff
are you in Auckland or chch?
I *may* be able to give you a hand to do it yourself, not that i've done it before :lol:
