Wheel studs
Wheel studs
Postby FEINT » Tue May 15, 2007 12:31 pm
Car is ST202 Celica 1996 with 3SGE.
I have stripped wheel stud and it needs to be replaced.
I have called Toyota and they want me to provide them with a sample. I can't really take it out as I need the car.
Is there a specific model / number or another car that shares the same wheel stud that I can tell Toyota?
Anybody here got a write up of how to take off the wheel studs?
FEINT
Postby strx7 » Tue May 15, 2007 12:51 pm
where abouts are you?
Postby postfach » Tue May 15, 2007 1:06 pm
ive never taken one out but surely they come out the same way as every other stud? just put 2 nuts on the thread and tighten them against each other, then undo the back nut and the stud should unscrew?
postfach
Postby sergei » Tue May 15, 2007 1:09 pm
Nope, they are pressed in, you need a good smack on it and it will come out (you will need to take the brake rotor off to do that).
Postby FEINT » Tue May 15, 2007 1:52 pm
I am in Auckland.
It is a real bitch trying to explain what it looks like to Toyota parts dept when they should know what it is!
I am going to try to take it off tonight, hopefully I can.
1) Remove wheel
2) remove caliper + bracket
3) remove rotor, that should just be with 1 or 2 screws right?
4) bang out old studs?
I was hoping to save all this hassle and get a mechanic to do it with a replacement ready. But it seems like everyone wants to see the original before giving me a replacement.
Thanks for the help guys! Keep the suggestions coming!
FEINT
Postby fivebob » Tue May 15, 2007 3:00 pm
FEINT wrote:I am in Auckland.
Then I would suggest that you stop dealing with parts monkeys and email Mr Revhead with your model and chassis codes, and get him to send you the right part http://forums.toyspeed.org.nz/viewtopic.php?t=44317;)
Postby sergei » Tue May 15, 2007 3:12 pm
1) Remove wheel
that is about right, the rotor is not held by anything, just make sure you place the hub in right position before you bang out the studs - it has got a cut out on the backing plate for puling out studs. You will see - it is straight forward.
pressing them it is a bit harder - clean hub before you do anything - aslo do not use wheel nut to "press" the stud, but if you have to put wheel nut upside down (conical bit facing you) and make sure there are couple of washers and plenty of lube when you do.
Postby FEINT » Tue May 15, 2007 6:03 pm
So the removing of everything sounds pretty straight forward, it is just getting the studs back in that ihave to have it 'pressed'? That means putting the stud through the hub and putting a nut (conical part Facing me)on the end and tightening it?
I will send Mr Revhead an email if the part monkeys can't match it up! Thanks alot for the help!
FEINT
Postby Mr Revhead » Tue May 15, 2007 9:32 pm
wtf :?
some times i really do wonder about some of the ppl doing my job in other dealerships.....
send that email and ill sort it for you 8)
Postby FEINT » Tue May 15, 2007 10:54 pm
Mr Revhead wrote:wtf :?
Thanks for that. I pulled everything off, here are the pics of the stud. :) Thanks guys for the input and help.
I will try to go to Toyota Link Drive tomorrow, if I can't find it, I will send you an email. Thanks for the kind offer.
FEINT
Postby bluemaumau » Tue May 15, 2007 10:56 pm
ouch :lol:
Postby fivebob » Tue May 15, 2007 11:30 pm
FEINT wrote:I will try to go to Toyota Link Drive tomorrow, if I can't find it, I will send you an email. Thanks for the kind offer.
hmmm looks suspiciously like a 90942-02049, but that's just a guess ;)
Postby Mr Revhead » Tue May 15, 2007 11:33 pm
farking hell fivebob...... if thats not ultimate geek i dunno what is :lol:
Postby fivebob » Tue May 15, 2007 11:41 pm
Mr Revhead wrote:farking hell fivebob...... if thats not ultimate geek i dunno what is :lol:
Knowing that a 90942-02052 is a 5mm longer replacement for this stud ;)
Postby fivebob » Wed May 16, 2007 12:04 am
Yep looks like it's a 90942-02049, same thread count anyway.
BTW the reason I know these numbers off by heart is I had to find longer studs for my SW20, went through all the different one's in Greenlane Toyota's shelves to find them.
Postby Mr Revhead » Wed May 16, 2007 9:57 am
front p/n 90942-02070
rear p/n 90942-02070 36mm
or 90942-02047 43mm
not 100% sure why the differing lengths, prob the longer one is for alloy wheels.
chances are that one fivebob posted will work too... 99.9% of toyota studs are the same thread pattern, its just the splines that are different
Postby FEINT » Wed May 16, 2007 12:07 pm
Mr Revhead wrote:front p/n 90942-02070
or 90942-02047 43mm
I just picked it up and it looks correct. I went to super cheap and the cost for 4 NUTS is $17!!!!!!
FEINT
Users browsing this forum: Google [Bot] and 20 guests
