3sgte knock sensor
3sgte knock sensor
Postby ALLTREC_TURB » Fri May 18, 2007 5:51 pm
Hey guys,
the knock sensor on my motor has the plug broken off it, I have got ahold of one from apparently a 5s or something, it all fits fine and looks identical apart for the plug, If i wire it up should it still work properly even though its from a different motor?
ALLTREC_TURB
Postby strx7 » Fri May 18, 2007 6:30 pm
yip, they all do the same thing and give off the same signal
Postby Mr Revhead » Fri May 18, 2007 7:53 pm
ah... are you sure about that?
Postby ALLTREC_TURB » Fri May 18, 2007 8:33 pm
yeah i wasnt too sure either, i went into toyota to buy a new one.....but for 400 bucks....$&#$% that
ALLTREC_TURB
Postby Mr Revhead » Fri May 18, 2007 8:35 pm
like hell they are $400
iv found with 4age/zes that they are not interchangable, and im fairly sure that goes for the 3sgte as well.
Postby vvega » Fri May 18, 2007 9:00 pm
Mr Revhead wrote:like hell they are $400
i used a 7a a 3sge and a 4age one in my 3sgte with no issues
vvega
Postby strx7 » Fri May 18, 2007 9:15 pm
JZGE, SGTE, SFE, AFE and SGE ones i've got at work are all the same thing, same plug even.
Postby ALLTREC_TURB » Fri May 18, 2007 9:48 pm
could you please get me a price then warrick? I thought i was way to steep, but meh.
So maybe ill ask a different question, is it going to do any damage if I try using the one I have
ALLTREC_TURB
Postby vvega » Fri May 18, 2007 11:08 pm
nope
worst it will do is put your car in limp mode
best it will do is atually work
vvega
Postby tex » Sat May 19, 2007 12:25 am
From my experience or (lack of it) they all the same pretty much but the plug. Obviously some might be more sensitive than others??
But as for 3sgte and 3sge they the same and work both ways. Plug different. I just cut end off and attach new plug and insulate it or just gut the casing part off and just plug the connector part in.
TEX
tex
Postby ALLTREC_TURB » Sun May 20, 2007 11:52 am
well i guess ill just give it a go and see what happens
ALLTREC_TURB
