electroplating engine parts
Postby deaf_rattle » Mon May 21, 2007 9:18 pm
Looking at getting some engine bits and pieces electroplating.
has anyone had this done?
pros? cons?
i know i cant get alluminium or alloy done, but still can get alot of brackets etc done.
pretty cheap too.
Re: electroplating engine parts
Postby Alex B » Mon May 21, 2007 9:24 pm
deaf_rattle wrote:i know i cant get alluminium or alloy done
You can get alloy done, just not alluminium :lol:
Postby deaf_rattle » Mon May 21, 2007 10:03 pm
sorry, am i missing something? :?
Postby KwS » Tue May 22, 2007 2:46 pm
thats right, you cant plate anything that has aluminium in it. the cleaning process just eats the $&#$% out of it.... quite cool really.
KwS
Postby deaf_rattle » Tue May 22, 2007 3:22 pm
yeah, i realised this, thats why i mentioned that i couldnt get alloy or alluminium done.
maybe pyro sniper needs a reading class :roll:
Postby thegreatestben » Tue May 22, 2007 3:56 pm
Maybe he is refering to alloy that isnt a type containing aluminium.
Alloy:
An alloy is a homogeneous mixture of two or more elements, at least one of which is a metal, and where the resulting material has metallic properties. The resulting metallic substance usually has different properties (sometimes significantly different) from those of its components.
thegreatestben
Double post action
thegreatestben
Postby fivebob » Tue May 22, 2007 4:55 pm
You can't get aluminium chromed without using some dangerous chemicals like hydroflouric acid. However you can get it nickel plated using an electroless nickel plating solution ;)
Postby GTCRSHR » Tue May 22, 2007 5:26 pm
where can you get it done pretty cheap ? i would be keen to get some engine bits and pieces done too
Nothing to see here ...
GTCRSHR
Postby deaf_rattle » Tue May 22, 2007 5:29 pm
Postby GTCRSHR » Tue May 22, 2007 5:38 pm
Fantastic its just down the road from me too cheers
GTCRSHR
