replacing engine
replacing engine
Postby AE86ID » Wed May 23, 2007 2:04 pm
i have a 1988 fxzi how hard will it be to put a 4age/4agze in there will the mounts be the same for the engine gearbox or do i require custom mounts ?
AE86ID
Postby AE86ID » Wed May 23, 2007 2:16 pm
some one must know ? come on :cry:
AE86ID
Postby Stealer Of Souls » Wed May 23, 2007 2:19 pm
12 minutes isn't long to get replies.
What engine does it have right now? Auto/manual?
What skills do you have?
'86 AE85.5 Levin
Stealer Of Souls
Postby AE86ID » Wed May 23, 2007 2:22 pm
its manual i think it has the 15oocc sohc i can do the engine swap myself just need to know if i need custom mounts
AE86ID
Postby RS13 » Wed May 23, 2007 3:04 pm
Have a look on the chassis plate, does it say 3A or 4A next to "engine"? I would have thought the FXZi came with a 4A, in which case you can use the factory mounts, as well as the factory gearbox for a 4AGE, however I think the GZE has a thicker flywheel that fouls on the bellhousing.
RS13
Postby AE86ID » Wed May 23, 2007 3:09 pm
yeah im pretty sure its the 4a so 4age is straight swap i just need new gb of 4agze? what would be better in the carolla you reackon ? as in fun/driveable on the street
AE86ID
