by RS13 » Wed May 23, 2007 3:04 pm
Have a look on the chassis plate, does it say 3A or 4A next to "engine"? I would have thought the FXZi came with a 4A, in which case you can use the factory mounts, as well as the factory gearbox for a 4AGE, however I think the GZE has a thicker flywheel that fouls on the bellhousing.
