Trademe fuel pressure regs.
Postby Crampy » Wed May 23, 2007 6:36 pm
Crampy
Postby postfach » Wed May 23, 2007 6:51 pm
My personal opinion is stick to a good known brand and don't buy imitation stuff, but often there are cheaper options out there which are still quality. I don't know of anyone who's used any of the ones you linked to there so I can't comment on those.
postfach
Postby Burning Angel » Wed May 23, 2007 7:59 pm
interesting, the third link says its a rising rate regulator but then goes on to say the ratio is 1:1 therefore making it linear(i think)
i probably wouldn't use a rising rate with a stock ecu as the mixture would become richer as load increases because of increased fuelpress. unless of course thats the desired result(ie more boost or summing)
Burning Angel
Postby AE82 FXGT » Wed May 23, 2007 8:10 pm
Your fuel system is not something you should skimp on.
I would hate to have the reg fail and drop pressure causing the car to run lean.
I got a sard one of fortyone.co.nz for $195, keep in ming you'll need a gauge on top of that price, and they gave me a great deal on both.
AE82 FXGT
Postby escortman » Wed May 23, 2007 9:20 pm
i bought one of them combo deals off TM 500hp walbro pump and sard reg for $430
4x4 toyota blizzard offroader
escortman
Postby 20v_rollaboy » Wed May 23, 2007 9:42 pm
Yep i agree, get a brand name one. Dont get one of the trade me $1 reserve specials.
We had one on a GT Starlet running a td04. Guage never worked from the beginning, and after a couple days was leaking fuel. Bought a Sard the next day.
20v_rollaboy
Postby gasman » Wed May 23, 2007 10:12 pm
i thought even your stock is raising rate 1:1 if your boosting it. the only difference is that you can adjust the preload on the diaphragm so that the overall pressure across the range will be higher
"What can possibly go wrong?"
gasman
Postby strx7 » Wed May 23, 2007 10:25 pm
some raise the pressure at say 1.2 or 1.4 psi fuel pressure for every 1psi boost pressure.
Postby matt dunn » Wed May 23, 2007 10:29 pm
Genuine? Bloody cheap if it was.
May have to look there myself.
Postby gasman » Wed May 23, 2007 10:31 pm
strx7 wrote:some raise the pressure at say 1.2 or 1.4 psi fuel pressure for every 1psi boost pressure.
makes more sense being a "raising" rate.
then in that case what are all tose tm tards going on about callint it raising rate 1:1 when a stock one can do that
gasman
Postby Crampy » Thu May 24, 2007 10:52 am
From what I understand, my stock Reg won't do that. It only works with vacuum and won't increase pressure with boost. My car is a stock 4AGE, which I'm turboing. Rising rate of 1:1 means it increases fuel pressure by 1psi for every 1 psi of boost, correct???. That's what I want.
I really need an adjustable reg, so I can get fuelling sorted, as I don't have much tunability with my setup, (No aftermarket ECU).
Crampy
Postby Crampy » Thu May 24, 2007 10:54 am
escortman wrote:i bought one of them combo deals off TM 500hp walbro pump and sard reg for $430
I've already got a Walbro pump off trademe for a good price. I hadn't heard of these combo deals when I got it though.
Crampy
Postby Crampy » Thu May 24, 2007 10:56 am
AE82 FXGT wrote:Your fuel system is not something you should skimp on.
Damn, that is a good deal.
I agree with you, my fuel system is something I shouldn't skimp on. For that much, it is definitely worth getting genuine.
So, Sard from fortyone.co.nz seems to be the best deal so far.
Crampy
Postby Crampy » Thu May 24, 2007 10:59 am
Also, does anyone know what the stock fuel pressure of a Bigport Redtop powered AE92 FXGT is? Is it 2.5 Bar or 2.9Bar?
Crampy
Postby strx7 » Thu May 24, 2007 11:01 am
most likely 2.9 bar most toyota's run 42psi base pressure
Postby Crampy » Thu May 24, 2007 11:23 am
Cheers.
Crampy
Postby AE82 FXGT » Thu May 24, 2007 7:15 pm
Yeah, genuine.
It was during the first groupbuy.
I paid and asked for an 8mm one but he sent me the RJ type (worth more), when I emailed him and asked about the mistake, he let me keep it!
So I got a $&#$% good deal.
Don't expect this to happen though.
AE82 FXGT
Postby matt dunn » Thu May 24, 2007 9:41 pm
Crampy wrote:From what I understand, my stock Reg won't do that. It only works with vacuum and won't increase pressure with boost. My car is a stock 4AGE, which I'm turboing.
A stock toyota reg will compensate for boost.
I actually think a GE and a GZE reg are the same.
I use a standard 20V on on my Turbo 20V race car and it raises at 1:1 on boost.
Matt
Postby method » Thu May 24, 2007 11:36 pm
My trademe one seems fine.
I dont really see how it could suddenly drop in pressure leaning your engine out unless the spring relaxes. But seeing as its not exposed to heat etc it wont happen.
1:1 rising rate FPR's are pretty simple, you could make one you're self..
All cars standard regulators are 1:1 and will rise on boost.
I wouldn't trust a non 1:1 thats cheap though. They are a little more sophisticated.
PICS UPDATED DAILY
method
Postby matt dunn » Thu May 24, 2007 11:43 pm
method wrote:My trademe one seems fine.
I wouldnt trust a non 1:1 thats cheap though. They are a little more sophisticated.
The problem with the cheap ones seem to be inconsistant pressures.
The base pressure, ie no vacuum or boost, will vary for no reason with temp and fuel flow, meaning that the fuel presure may vary across the whole scale between one run and another for no reason.
We had a crap one on the focus which had data logged fuel pressure and the readings were all over the show. We ended up with a sard, and now the fuel pressure curve exactly matches the manifold pressure curve.
