AE82 FXGT wrote:
I got a sard one of fortyone.co.nz for $195,
strx7 wrote:some raise the pressure at say 1.2 or 1.4 psi fuel pressure for every 1psi boost pressure.
gasman wrote:strx7 wrote:some raise the pressure at say 1.2 or 1.4 psi fuel pressure for every 1psi boost pressure.
makes more sense being a "raising" rate.
then in that case what are all tose tm tards going on about callint it raising rate 1:1 when a stock one can do that
escortman wrote:i bought one of them combo deals off TM 500hp walbro pump and sard reg for $430
AE82 FXGT wrote:Your fuel system is not something you should skimp on.
I would hate to have the reg fail and drop pressure causing the car to run lean.
I got a sard one of fortyone.co.nz for $195, keep in ming you'll need a gauge on top of that price, and they gave me a great deal on both.
Crampy wrote:From what I understand, my stock Reg won't do that. It only works with vacuum and won't increase pressure with boost. My car is a stock 4AGE, which I'm turboing.
method wrote:My trademe one seems fine.
I dont really see how it could suddenly drop in pressure leaning your engine out unless the spring relaxes. But seeing as its not exposed to heat etc it wont happen.
1:1 rising rate FPR's are pretty simple, you could make one you're self..
I wouldnt trust a non 1:1 thats cheap though. They are a little more sophisticated.
