***4agze pulley kit***
Postby corolla gt » Thu May 24, 2007 7:12 pm
hi i have a aw11 4agze bigport and am wanting to no bout the right pulley to get...it has been fully rebuilt and hasnt been runn in yet so i am thinking the 175mm 14psi pulley?
but i have a feeling from lookn at the motor that it wont fit....there is like a toothpick looking think above my crank pulley.i think it is a tensioner for the belt
would that have to be removed to fit the 175mm pulley my standard one is 155mm ......and will i have to do something about the waterpump pulley pretty dam close if it had a 14psi pulley...
any help guys
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby AE82 FXGT » Thu May 24, 2007 7:36 pm
You have to cut that piece down to clear the pulley,
as far as I'm aware you won't have to touch the waterpump pulley, but you'll need a new belt tensioner. The one that sits to the top left of the crank I think.
Someone correct me if I'm wrong.
AE82 FXGT
Re: ***4agze pulley kit***
Postby pidge » Thu May 24, 2007 7:46 pm
corolla gt wrote:there is like a toothpick looking think above my crank pulley.i think it is a tensioner for the belt
any help guys
The "Toothpick looking thing" is probably the timing marker. If you bought the pulley in a kit, there will be a replacement one, along with a replacement idler pulley.
pidge
Postby Crucible » Thu May 24, 2007 11:25 pm
a 175mm one will clear the waterpump, just chop the pointer off.
make sure the keyway/key is'nt damaged, Clean everything and use heaps of loctite on the snout and crankbolt.
do it up F@#$n tight :P
Crucible
Real Life Mechanic
Postby evil_si » Fri May 25, 2007 9:00 am
any help guys
cusco kits use to come with a new timing pointer, they retailed in nz for $1600
evil_si
Postby corolla gt » Sun May 27, 2007 9:34 pm
i mite but a 180mm pully for my car now...but im shore it will hit the water pump pully is there anyway i can get the water pump pully machined down to make it fit like get 5 or 10mm of water pump lip?
corolla gt
Postby escortman » Sun May 27, 2007 10:09 pm
yeh the 14psi pulley is the biggest u can go with out touching the waterpump .. just, i think i was told somewhr that uc an use the cam idler to replace it
4x4 toyota blizzard offroader
escortman
Postby evil_si » Mon May 28, 2007 10:40 am
some mazdas have a similar water pump pulley, a lot quicker and easier to get a new one made thou,
i dont recommend any thingover 175mm
if you want more power / boost just go turbo, a good turbo setup is way better
evil_si
Postby corolla gt » Mon May 28, 2007 6:30 pm
so what 16psi pully ant gona be worth it on a sc14 super charged motor? i cnt go turbo dont have the cash but im not shore if u can runn 16psi on standard ecu and i thought maybe the sc14 would give it more boost anyways since it bigger than the sc12?
so it will just pretty much be a gas guzler on the 180mkm pully
best option 175mm 14psi?
corolla gt
Postby Crucible » Mon May 28, 2007 8:59 pm
boost cut is at 15psi on ae101 ecu, 175mm pulley is the last upgrade before thinking about going to turbo.
you may see 14psi with a 175 pulley but boost depends entirely on the condition of you're blower.
Crucible
Real Life Mechanic
