starter motor probs
starter motor probs
Postby Dirtbag » Sat Jun 02, 2007 3:38 am
when i turn the key the starter motor screams away, but only sometimes actually starts spinning up the engine, sometimes itll engage right away (like usual) sometimes i have to try it about 5/6 times 2 second blasts to get it to engage. Its just randomly started happening, as far as I can remember only thing changed has been the side engine mount (battery side ae101)
any help on diagnosing the problem would be much appreciated
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby mr30%jr » Sat Jun 02, 2007 6:55 am
sticky throw solenoid... either get a replacement or get adventurous and take it off and apart and clean it out.
mr30%jr
Postby ChaosAD » Sat Jun 02, 2007 1:28 pm
I find a bit of encouraging wight something heavy sometimes does the trick lol
ChaosAD
Postby Dirtbag » Sat Jun 02, 2007 6:20 pm
so giving starter motor a bit of a tap might get the solenoid working better?
My profile!
Dirtbag
Postby JRS » Mon Jun 04, 2007 5:03 pm
if the solenoid doesnt pull in the contacts wont touch and the motor wont spin at all. the one-way clutch on the pinion might be slipping. or damaged teeth on the pinion or ring gear.
meh.....
JRS
Postby matt dunn » Mon Jun 04, 2007 9:48 pm
JRS wrote: the one-way clutch on the pinion might be slipping.
That would be my guess. Quite common on some type of starters.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
