Silver top ae101. Engine check light
Postby tex » Wed Jun 06, 2007 2:32 pm
Engine check light is permantly on. Reset the ecu, can't get any codes off it. Tried in plug in ODBC1 tool and did teh same thing.
Car runs like a bag of shit. won't rev out, and running very rich. like in limp mode. High k's on the motor. Doesn't sound like dentonation, but does have a bit of a rattle up the top. Was think knock sensor causing it, but no codes at all.
Attempted to try and unplug the knock sensor form the block but it in a pig of a spot.....grrr
Will try ecu next. Any other suggestions??
Thanks
TEX
tex
Postby Punter » Wed Jun 06, 2007 2:38 pm
Sounds like what mine did when the ECU lunched it's self.
Make sure you're bridging the correct wires in the diagnostics port, if you are and are getting no codes, it's most likely a dead ECU
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Postby Mr Revhead » Wed Jun 06, 2007 2:46 pm
yeah suspect dead ecu there.
leaky capictors....
about time some one who has repaired that did a write up we can FAQ
Postby AceSniper » Wed Jun 06, 2007 3:23 pm
haha iv fixed afew but no one really worrys about it.
SOunds very much like dead caps...
open it up look for two leaking caps, its always the same two
AceSniper
Postby matt dunn » Wed Jun 06, 2007 9:11 pm
Manual or Auto?
I may be able to do an exchange ECU for yours + cash if it's the ecu.
Sounds very much like the one I did a while ago that was an ECU fault.
Postby slighty_sykotic » Thu Jun 07, 2007 9:41 pm
And if its manual OR auto, I can sort you out a loan ecu to test if thats the problem before you buy one from matt or someone.
You've got my msn.
slighty_sykotic
