Heater Core Question!
Postby Knickers » Thu Jun 07, 2007 12:03 am
Need a little insight!
Im currently in search of a ae82 FXGT heater core for the fx (looking for one around the Manawatu area, if you know of one :D), as i had discovered after purchasing the damn thing, it has no heater. Im aware (from the ex and the mechanic dad) that all the little 'bities' are still there.
Ok what im wanting to know is that if i cannot locate another ae82 core, can i use another core from another simular corolla? Like the liftback one or does it HAVE to be a ae82?
Thanks
Hannah
Knickers
Postby strx7 » Thu Jun 07, 2007 7:33 am
any #E80/81/82 series corolla should have the same heater core
Postby big_boy » Thu Jun 07, 2007 11:48 am
i have a AE82 core in my EE90 fits fine except these one extra bolt but it dousent really matter it theres still about 11 from memory holding it
for sale EE90
big_boy
Postby gepsk8 » Thu Jun 07, 2007 6:36 pm
jump on trademe sure some1 will have 1 for sale.
gepsk8
Postby slighty_sykotic » Thu Jun 07, 2007 7:01 pm
Have you checked the core isnt there?
I can't remember if you did or not.
Put a hose on one heater pipe in the engine bay, (turn heater to hot inside car) and see if water comes out the other one. If it does, check your passengers footwell isnt fulling up with water. If not, then you just need to connect the pipes up.
slighty_sykotic
Postby Knickers » Thu Jun 07, 2007 11:16 pm
slighty_sykotic wrote:Have you checked the core isnt there?
I wouldnt know what a heator core looked like if it stood up in my porridge... Ill get dad onto it tomorow!
Knickers
Postby Dell'Orto » Thu Jun 07, 2007 11:22 pm
They are available new if you get uber desperate, cause they aren't cheap 8O (ie over $200 for a KE70 one 8O )
Postby TOYWGN » Thu Jun 07, 2007 11:50 pm
if you see two brass heater pipes sticking out of the firewall theres a heater there dude...... :D
1997 Jzx100 Tourer v !!!!
TOYWGN
Postby slighty_sykotic » Thu Jun 07, 2007 11:51 pm
no...
it doesnt mean they are connected, or that it doesnt leak.
It means you have water pipes sticking out.
slighty_sykotic
Postby Knickers » Sat Jun 09, 2007 12:10 am
The core is definatly bung.. Dash started pissing fluid.
Tried putting some anti leak stuff with no luck.
Found a ae82 core from the wreckers :)
Thanks everyone :)
Knickers
