****best aftermarket ecu for 4agze****
Postby corolla gt » Wed Jun 13, 2007 6:22 pm
hi guys i have put alot of thought into it and now have decided to go for the aftermarket ecu for my 4agze tht im putting my starlet.....i have got the 4agze loom cut down and shortend for rwd but it will b a bit small and my starlet is already 4age wired up.
i thought bout it and now i think i will keep all the 4age bluetop loom in my car and get a better computer for the turbo
it will probley save me money as i will have to get loom quiet a bit longer and then my alternator will be on exhaust side and all my bluetop wiring will b a big waste...
so could u guys give me sum good examples of pretty good ecus for 4agze ....i dnt really have the money for link :lol: but yea was thinking around the lines of piggy back ecu
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby escortman » Wed Jun 13, 2007 7:29 pm
y not save u can get links for 1000 buks, i think they did a groupbuy not long ago and G3 was only 1200 from memory, plus links have fuk all sensors etc to run so less wiring
4x4 toyota blizzard offroader
escortman
Postby TRD_ZERO » Wed Jun 13, 2007 7:50 pm
Get a link support NZ
TRD_ZERO
Postby slighty_sykotic » Wed Jun 13, 2007 7:52 pm
Um, what are you going to put the piggyback computer onto? the std bluetop ecu?
Far far far far far far better off getting the 4agze loom in there.
Or if you go aftermarket, then link is about the cheapest. Find a second hand older verison LEM. $500ish
slighty_sykotic
Postby l1ttle_d3vil » Wed Jun 13, 2007 9:19 pm
there was a turbo link - which had been upgraded to an lem v5 - on trademe for about $350 last week...
Postby corolla gt » Thu Jun 14, 2007 1:08 am
are the turbo links hard to install though have been told by speedtech that they are and they dnt touch them
i dnt really want to destroy all my bluetop wiring though as my car is all wired up and has worked allgud plus my alarm is connected up sumhow to my computer to so i will have 2 get tit all changed and then get the wiring all madeto fit my car.
....i think it will b a bit of a mission
i looked on trade me and there is a trust E ecu piggy back for 450 i am keen on thatthe guy said it will b good for a ae86 and my bluetop motor is a ae86 originally
corolla gt
Postby slighty_sykotic » Thu Jun 14, 2007 1:33 am
seriously, if your not going to listen to us, why ask?
Piggy backs are great for small changes, ie, adding a bigger turbo to an already turbo.
In my opinion, going from non turbo to turbo needs more than a piggyback.
And if your only reason is that you don't want to mess up your loom, then your reasons are really backwards.... Plus the fact that emanage is going to have to be split into your loom anyway.
--Sykotic
slighty_sykotic
Postby corolla gt » Thu Jun 14, 2007 6:08 pm
ok then so putting the agze loom in would b a better idea i think the ze loom will fit into my rwd bluetop inklet and stuff so yea could be allgud or maybe a link like u guys said i guess
corolla gt
