Lock-Tight bolts
Lock-Tight bolts
Postby Zyros » Thu Jun 21, 2007 12:40 am
Hey, me and my mate doing a manual conversion of a cefiro.
( I know it aint toyota, sorry)
He put Lock-Tight on the bolts to the flywheel, but.. after that we realised that we didnt take the auto spigot bush out, so now gotta un-do those bolts..
Will it come off easy, any tips?
Zyros
Postby postfach » Thu Jun 21, 2007 12:42 am
will be harder than if there was no loctite, i think you can heat them and it breaks it down a bit, you wanna be careful around that area though i'd say, other than that, just use a really long bar
postfach
Postby Bling » Thu Jun 21, 2007 12:42 am
only one way to know..... attempt to undo them and find out :lol:
Postby Grrrrrrr! » Thu Jun 21, 2007 1:12 am
i hope he didn't use super-high strength loctite. it'll be a b%^&h if he did. Big power bar and you should be fine if it was medium strength loctite.
Grrrrrrr!
Postby Dragger_Dan » Thu Jun 21, 2007 11:25 am
Recently had to take my flywheel off to change the backing plate for my gearbox. Makes it hard, but not impossible to get off. Big power bar FTW.
Dragger_Dan
Postby DIRTYDX » Thu Jun 21, 2007 2:16 pm
Borrow a compressor and rattle gun and shock those c**ts undone bro,otherwise if u have access to a gas set put abit of heat on each bolt as metioned above as it breaks the loctite down,or else get hold of a flogging spanner and club hammer and crack each bolt or yea long power bar with a bit of pipe on it for extra leavarage
DIRTYDX
Postby postfach » Thu Jun 21, 2007 3:34 pm
DIRTYDX wrote:long power bar with a bit of pipe on it
off topic, but that reminded me of a nut we undid at pick-a-part on the weekend, we found a 2.5m long pipe and used it on a 3/4" drive power bar, undid it no worries!
postfach
Postby big_boy » Thu Jun 21, 2007 4:10 pm
postfach if you want a we hint when doing that rap a rag arround you strong arm that way when you use the pipe & break the pin of the bar theres no scratches arround the bar so you still get warrenty:)
DIRTYDX heat is probly not the best fix for arround this area as it will make the berring harder to get out when flywheel is off & ma stuff the berrings or seals
for sale EE90
big_boy
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
