not sure if anyone will have a definite answer, but which would be the easiest / cheapest struts to do a good brake upgrade on - ke35 or ae85?
would want something like 10" vented disks, for a 4agte conversion.
i know with ae85 brakes you can bolt the ae86 disks + brakes on but I would want something bigger than that, and I'm sure I could get something better for probably the same price! is there anything bigger which would bolt on with relatively few mods?
as far as I know there is nothing bigger that will bolt on to the ke35 struts.
obviously both struts would need modifying, but which would be easiest / require least mods to fit bigger brakes? or would they both require the same sort of work?
thanks.
