easiest struts for brake upgrade - ke35 or ae85?
Postby l1ttle_d3vil » Sat Jun 23, 2007 2:19 pm
not sure if anyone will have a definite answer, but which would be the easiest / cheapest struts to do a good brake upgrade on - ke35 or ae85?
would want something like 10" vented disks, for a 4agte conversion.
i know with ae85 brakes you can bolt the ae86 disks + brakes on but I would want something bigger than that, and I'm sure I could get something better for probably the same price! is there anything bigger which would bolt on with relatively few mods?
as far as I know there is nothing bigger that will bolt on to the ke35 struts.
obviously both struts would need modifying, but which would be easiest / require least mods to fit bigger brakes? or would they both require the same sort of work?
thanks.
Postby tenyearguarantee » Sat Jun 23, 2007 4:30 pm
im looking at doing a crx disk conversion on my ke10, it uses 236mm vented disks onto standard hubs. Havent done it yet but its seems do able. Otherwise i know people who have made Cressida struts fit ke20s, will need some work tho
tenyearguarantee
Postby Mr Revhead » Sat Jun 23, 2007 7:05 pm
so you have ae85 ones as well?
iirc skyline calipers bolt to the ae86, so theres an option
a search through the DBA catalouge may find you some bigger rotors that will fit.
you can also look at the #a6# series celicas etc for bigger brakes.
though they will prob need more mods to fit.
Postby aaron » Tue Jun 26, 2007 2:41 pm
look in to early celica struts they are far bigger and vented they are pretty simple to fit from what I can remeber on ke3*s. will have to talk to a mate of mine about it the convesion was done 2 years ago im a little hazey.
Owned cars:
4age powered 1973 ke25 corolla
4k powered 1974 ke25
AE101 20v trueno
AE92 Levin
http://toyspeed.blakjak.net/profiles/profile.php?id=68
aaron
Postby rollaholic » Thu Jun 28, 2007 7:37 pm
theres probably alot more info out there on the ae85/6 setup, might be easier to find something workable without having to invent it from scratch.
Postby d1 mule » Thu Jun 28, 2007 7:52 pm
get GX71, GZ10 struts or similar, then get R30 hubs and GTST calipers and discs. its all a bolt on affair bar the 1mm washer on that caliper. in saying that tho, im sure "just a GX71 or GZ10 brake setup would be more than sufficent in a SR coupe, hell even AE85 is a BIG improovement, i just put really good pads ($400 retail) and fluid in my old ae85 and it stopped on a dime. :D
d1 mule
