Rod weights
Rod weights
Postby TRD_ZERO » Sun Jun 24, 2007 2:31 pm
Im wanting to know the difference in rod weights between the aftermarket rods whether it being crower, porter, eagle or whatever to the ae92 gze rods and how they affect the revyness of the engine. Are the aftermarket ones alot lighter letting the engine rev out more? Im going to be running ae92 rods in my blacktop turbo. I had been told if i use these rods i wont really be able to rev my engine out very far because of the wieght of the rods. Is this true?
TRD_ZERO
Re: Rod weights
Postby matt dunn » Sun Jun 24, 2007 6:58 pm
TRD_ZERO wrote:Is this true?
No it's a load of shit..
Postby Dell'Orto » Sun Jun 24, 2007 7:00 pm
The bigport GZE's redline at 7500, so they can't be all that bad ;)
Postby Mr Revhead » Sun Jun 24, 2007 7:11 pm
lighter rods wil help the engine rev a little faster...
but i doubt very much youl be able to tell the differenve!
the main advantage over the aftermarket rods is strength.
having said that...... only the blacktop rods are of dubious strength. and many ppl have made LOTS of power at upwards of 7500 rpm on stock rods.
so when choosing rods, as with most parts.... whats the intended use?
Re: Rod weights
Postby TRD_ZERO » Sun Jun 24, 2007 7:22 pm
TRD_ZERO wrote: Im going to be running ae92 rods in my blacktop turbo.
TRD_ZERO
Postby Mr Revhead » Sun Jun 24, 2007 7:28 pm
sorry, wasnt meaning you specificly, more of advice to others reading the thread. think about the use it will get when choosing parts.
ie if you intend to run 400 at 9000 rpm, go aftermarket...
but if 300 at 7000 or so is yout goal, stock 4age pre BT will do
Postby TRD_ZERO » Sun Jun 24, 2007 8:57 pm
Oh yeah ok i was just worried the ae92 gze rods were gonna be abit heavy and wont be able to rev it out to say 8200.
TRD_ZERO
Postby Mr Revhead » Sun Jun 24, 2007 9:11 pm
they will do that
but i recomend some shotpeening etc
Postby AceSniper » Sun Jun 24, 2007 9:35 pm
balancing the bottom end is another place you should be looking
AceSniper
