slight whinning noise (noticable) when in neutral sitting there, put the clutch pedal in like 1" (not disengaging/engaging clutch) and it goes away, and when decelerating when revs drop from 2.5k to 1k theres a weird whinning also. any ideas? cheers
Ae92typeX wrote:could also be input shaft bearing if you can hear in neutral with foot not on clutch. that could explain the noise when on the move also
