slight whinning noise (noticable) when in neutral sitting there, put the clutch pedal in like 1" (not disengaging/engaging clutch) and it goes away, and when decelerating when revs drop from 2.5k to 1k theres a weird whinning also. any ideas? cheers
Ae92typeX wrote:could also be input shaft bearing if you can hear in neutral with foot not on clutch. that could explain the noise when on the move also
Users browsing this forum: Bing [Bot] and 4 guests
