Okay.
One.
Are the T series known for having a crown wheel and pinion "weakness". I have just worn out a crown wheel and pinion in my T series rear end. The original one in the diff was worn. The first second hand replacement didn't last long (was a little whiny to begin with), and the latest one did better, but is now also a bit goneburger...
In all three cases is seems that the crown wheel and pinion have worn the top hardened surface away and are now grinding.
Two.
Are all RWD final drives helical cut? Why can't the be straight cut? Especially if being used in a more heavy load situation.
Three.
With my Crown wheel and pinion goneburger I'm faced with something of a decision. The second part of my problem is that one axle has a slight bend in it. Just enough to be a pain in the A.
I'm faced with the thought that perhaps i shelve all the current bits for my other car and replace the guts with the late model gear.
Will this work. I have an early model housing and want to put all late model gear on the inside.
Is this a definite 100% guaranteed straight swap. Just buy the late model LSD, axles, and bearings and put it in? Or do you need to change other fiddly little bits?
