I believe it needs to have a circuit to know the ignition is on so it can charge which it doesnt have. So I need to know what colour wires I should be using off the alternator to make that circuit. It should still be in place behind the dash so I can work from here.
Also in the bottom pic does anyone know where I should connect the wires. There is a bit that says IGN so maybe that?
I would have consulted my kp60 maual because its really helpful but the bastards stole it from the garage as well
Thanks in advance.
