kp60 wiring help
kp60 wiring help
Postby ollieboy » Sat Jul 21, 2007 5:25 pm
After my car was burgled and broken a few months ago (who the $&#$% wants to steal a 4k) I have been working at fixing it. I had to rewire a huge bit of the loom and am now having trouble with getting the alternator to charge. I'm thinking it must be wiring because the Alternator is ok.
I believe it needs to have a circuit to know the ignition is on so it can charge which it doesnt have. So I need to know what colour wires I should be using off the alternator to make that circuit. It should still be in place behind the dash so I can work from here.
Also in the bottom pic does anyone know where I should connect the wires. There is a bit that says IGN so maybe that?
I would have consulted my kp60 maual because its really helpful but the bastards stole it from the garage as well :cry:
Thanks in advance. :D
ollieboy
Postby andyztouring » Sun Jul 22, 2007 8:16 pm
You should have a plug for the dash loom,which plugs into the gauge cluster,into the slot to the left of the nuts and screw,no wires are bolted on the ign nut.
andyztouring
Postby ollieboy » Sun Jul 22, 2007 10:29 pm
Ok, I'll have a hunt round tomorrow, the cars an absolute mess so its a bit of a mongrel and I suspect I will have to rewire it anyway.
ollieboy
Postby ollieboy » Tue Jul 24, 2007 1:39 am
I couldnt find any plugs behind the dash that would fit but its all sorted, I got sent a wiring diagram by email so tomorrow I'm going to be having lots of fun rewiring :)
ollieboy
