1JZGTE Waterpump
1JZGTE Waterpump
Postby RickGT » Thu Aug 02, 2007 11:41 pm
Looking for a new waterpump to replace the hydraulic waterpump assy, tried a 2jzgte one and it doesnt line up, went to Toyota an they only list 1 pump for 1jzgte which is the hydraulic, but there is a listing for a 1jz-ge one that is just the water pump, would this fit onto 1jz-gte?
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby spencer » Thu Aug 02, 2007 11:51 pm
my 1jzgte had a normal fan on it, used the repco listing for the pump bolted up fine. dont know if the 1jzge housing has the water lines that run around to the oil cooler
ms63 crown
spencer
Postby RickGT » Thu Aug 02, 2007 11:55 pm
how much did you pay for it? and i think the oil cooler lines come off the rear housing off the pump iirc
EP91 Glanza V
RickGT
Postby spencer » Fri Aug 03, 2007 8:24 am
about 30-40 on staff, was just saying that as toyota usually sells you the whole housing
ms63 crown
spencer
Postby MrOizo » Fri Aug 03, 2007 9:56 am
I used the 2JZGTE pump (front and rear housings). You have to use a complete 2JZGTE setup (including the Pulley too)
Just make sure you sort a switch out for the electric fan if thats where you go of the viscous setup off the JZA80. I had a switch and kept forgetting it when i got into traffic and i could hear the 'kettle boil' :oops:
MrOizo
Toyspeed Legend
Postby postfach » Fri Aug 03, 2007 9:58 am
Non-Hydraulic water pump - Part Number 16100-49846
Non-Hydraulic water pump pulley - Part Number 16371-46020
They will tell you that those numbers aren't listed for any of the cars you might expect to get a 1JZ-GTE out of, but trust me, they are the right parts, I have them in my car. My pump came as a complete unit (minus the pulley, which is why I've supplied the part number for it) with all the seals etc that you would need.
It looks like this:
(click for bigger image)
postfach
Postby strx7 » Fri Aug 03, 2007 10:17 am
that looks like a run of the mill 2JZGE pump
Postby RickGT » Sat Aug 04, 2007 1:23 pm
postfach wrote:Non-Hydraulic water pump - Part Number 16100-49846
It looks like this:
Sweet cheers for that, gettin revhead to get me a price, but i had the number 16100-49845 but aparently doesnt show up on the system
EP91 Glanza V
RickGT
