and I know its been asked before but i'm being a bit more specific than most (i think!): what are my options as far as turbos go for 200+kw atw?
don't think a little vf10 is going to cut it...
cheers.
l1ttle_d3vil wrote:what sort of kw would a 450x350x60 frontmount intercooler be able to handle? would 200+kw be a safe amount? this would be on a 4age turbo. and how much smaller could I go safely? the above size is about the largest I could run before I have to get the grinder out, which I would rather avoid!
don't think a little vf10 is going to cut it...will be an aw11 4agze so can run lots of boost!
will be street driven not track so don't want anything too laggy. and i HAVE searched and read through a few pages and haven't found anything definite. about all I can find so far is a t04e, is there anything else?
cheers.
l1ttle_d3vil wrote:sweet thanks guys.
found this turbo on TM for under $400. does the "rated at 230kw" mean thats the max it could do, or thats what it will do quite comfortably with room for more?
flygt4 wrote:200kw isnt actually that much power, and if you get a large turbo you won't really be using it to its potential and have more lag than you need.
flygt4 wrote:id be looking at standard turbos off 2L engines, mitsi tdo5's are very good and also very cheap at ~$400-500 2nd hand
tsoob wrote:i have a ht18 t3 you can buy if you are interested
l1ttle_d3vil wrote:flygt4 wrote:200kw isnt actually that much power, and if you get a large turbo you won't really be using it to its potential and have more lag than you need.
are you saying the T3 above is a large turbo or just meaning in general terms?flygt4 wrote:id be looking at standard turbos off 2L engines, mitsi tdo5's are very good and also very cheap at ~$400-500 2nd hand
is the td05 alot better than a t3/t4? as those t3/t4s are under $400 brand new. seems a decent price to me compared to other brand new turbos around or even 2nd hand ones for that matter.
