TURBO MOUNTING ANGLE
Postby Voyeur » Fri Aug 17, 2007 12:50 pm
Hey guys, i am just doing the final planing for my 20V turbo conversion, and have a question on the placement of the turbo. If i mount the turbo with the inlet on a 30 degree angle then it will give me less headaches in clearance for the oil filter, and also less bends in th IC pipework. Is this ok or should the turbo be kept as close to horrizontal as possible
Voyeur
Postby IH8TEC » Fri Aug 17, 2007 1:08 pm
MOST turbo's you can rotate the housings around the center section. try keep the oil feed/drain as vertical as possible, although some manufacturers have a limit on the angle the oil feed/return can be
Postby Phothog » Fri Aug 17, 2007 1:32 pm
idealy the turbo should be dead flat... but this is not the case some times..
the compressor cover & turbine housing should be level,
the bearing housing, Garrett recomend no more that 22deg off centre line.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby Voyeur » Fri Aug 17, 2007 1:34 pm
Cheers, thats what i needed to know
Voyeur
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
