build plate/VIN questions
Postby RomanV » Sun Aug 19, 2007 9:25 pm
Just a few questions, in case anyone here knows.
I've had to remove my build plate, and scratched it in doing so. I'm planning on re-riveting it to the firewall, but it's gonna look like its been swapped.
The last thing I want is some c**t digging my brand new paint off my firewall looking for weld marks where my chassis number is stamped on. :evil: What's the best thing for me to do from here?
Is the built plate necessary? I mean I'll have a cert plate, and all of the old information on the build plate is redundant.
Seeing as how it's going to have a different engine/gbox/diff/etc.
Seeing as how the chassis number is still there, stamped onto the firewall.
On the LTSA site it says that if the build plate has been removed, then you must get a VIN. Does this mean that if you've got a VIN, you can remove the build plate without any ramifications? Mine is pretty rangy looking! And if you dont have a build plate, how would anyone know that your engine etc isnt what came with the car from factory?
Postby Lloyd » Sun Aug 19, 2007 9:34 pm
Just stick it back on. You'll probably have a VIN anyway? And if not you have the VIN stamped in the body which will match up to your rego number anyway
Hell, just screw it on
Postby RomanV » Sun Aug 19, 2007 9:40 pm
Yeah the VIN process only started in 1991 or so, I dont think that my MR2 has a VIN number either....
Postby Zak » Sun Aug 19, 2007 10:31 pm
My 86 was imported in 91 and has no vin plate, uses the chassis plate insted , I think I perfer it that way too, vins are ugly :lol:
Zak
Postby z|gen » Sun Aug 19, 2007 11:17 pm
heh..on this subject kind of..
my landcruiser doesnt have a Vin number stamped anywhere..to make things worse..the build plate is so old, theres nothing even written on it anymore..was quite a mission to find the frame number to change owner ship :(
AE91 SUPERCHARGED COROLLA
z|gen
Postby strx7 » Sun Aug 19, 2007 11:18 pm
you dont even need the build plate, all it needs is the chassis number which is on the firewall.
Postby no_8wire » Fri Aug 24, 2007 8:53 am
my NZ new camry doesnt have a build plate...neither did my brothers NZ new subaru...
So I would say you could get away with it.
no_8wire
