4age into carolla
4age into carolla
Postby AE86ID » Sat Aug 25, 2007 10:52 am
hey everyone just a couple of questions
i have a 89 fx-zi with the 4afe i think i have just aquried(sp) a blacktop 4age with 5 spd g/b will the engine and gear box bolt into the old mounts or will in need to be modified ? and if it needs to be modified how much and is it worth it ?
thanks for your time hopefully someone knows
AE86ID
Postby AE86ID » Sat Aug 25, 2007 11:09 am
oh and if it cant be done anyone want to buy a blacktop 4age with box?
AE86ID
Postby Mr Revhead » Sat Aug 25, 2007 11:46 am
research would tell you that yes it can be done
worst case scenario means you buy new ae111 mounts but the car it self wont need altering
Postby AE86ID » Sat Aug 25, 2007 11:50 am
i did search found nothing i have a whole donor car so it should be a straight swap then if i use the 4age ecu will it plug into the fxzi loom ie no wiring involved plug and play ?
AE86ID
Postby rollaholic » Sat Aug 25, 2007 11:54 am
you'll want to change the loom too
Postby AE86ID » Sat Aug 25, 2007 12:07 pm
is it really important to do so i will be running fxgt cluster i dont want to mess around with wires its only my daily so not looking at spending big bucks
AE86ID
Postby Mr Revhead » Sat Aug 25, 2007 12:19 pm
you need to run the loom to run the engine.....
you cannot just bolt it in and drive away.
you need to wire in the ecu and blacktop loom.
Postby AE86ID » Sat Aug 25, 2007 12:22 pm
so the fxzi loom will not plug into 4age ecu ? i can do the conversion myself just no good with wires
AE86ID
Postby matt dunn » Sat Aug 25, 2007 8:37 pm
you will find that you will definatly need the whole 20V engine loom for the engine bay,
and that the 20V engine loom will not be able to plug in to connect
with the current car dsh loom so an amount of wiring will required no matter what.
Postby themaleman » Sat Aug 25, 2007 11:57 pm
u shoulod have a blacktop engine loom and copmputer
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby AE86ID » Sun Aug 26, 2007 6:30 am
i have both the loom and computer im not talking about engine loom im talking about the rest of the car ie brakelights and such
AE86ID
Postby ChaosAD » Sun Aug 26, 2007 8:59 pm
youll need the engine loom, all the plugs are different
ChaosAD
Postby matt dunn » Sun Aug 26, 2007 10:14 pm
AE86ID wrote:i have both the loom and computer im not talking about engine loom im talking about the rest of the car ie brakelights and such
No matter what or how many loom you have, there is no plug in option.
Wiring will be required.
The "rest of the car loom" from the 20V setup wont plug into your dash, heater lights wipers windows or basically anything electric.
and the engine loom is also part of the whole vehicle as in the power supply for the whole car runs through the engine loom which you will need to change.
