Caldina GTT Head
Caldina GTT Head
Postby Caldina3SGTE » Sun Aug 26, 2007 6:20 pm
just wondering will a altezza 3sge head fit on a caldina 3sgte block?? if not, wht head will bolt stright on a caldina block?
Caldina3SGTE
Postby strx7 » Sun Aug 26, 2007 7:37 pm
its obvious why you'd want to bolt the twin vvti head on, but why any other head, has yours cracked or something? they are a reasonably good flowing head if you want to make more HP
Postby fivebob » Sun Aug 26, 2007 9:01 pm
Any Gen III head would fit but you'd need the distributor and an aftermarket ECU to make it work.
Why would you want any other head? The stock 3S-GTE head is not a performance restriction. :roll:
Postby Caldina3SGTE » Sun Aug 26, 2007 9:48 pm
just curious thats all, and yea kinda want the vvti, yea just got my caldina not to long ago and don't know that much about them thanks
Caldina3SGTE
Postby strx7 » Sun Aug 26, 2007 9:51 pm
if you wanna make it fly, change the pistons, change the turbo/manifold, do the rest of the usuals - cams, ECU, fuel pump, etc etc and you're good for over 400hp
as with most vehicles, the limit to the power is the depth of your pocket
Postby snwtoy » Mon Aug 27, 2007 5:48 pm
strx7 wrote:if you wanna make it fly, change the pistons, change the turbo/manifold, do the rest of the usuals - cams, ECU, fuel pump, etc etc and you're good for over 400hp
That should say 'Do the ECU...' then everything else.
snwtoy
Postby caldinagtt » Mon Sep 03, 2007 10:49 pm
pistons, rods, t70 turbo, manifold, fuel pump, fuel regulator, 870cc injectors, exhuast, 50mm wastgate, bov, intercooler, breather tank and a link has netted me 253.1 kws atw on 13.4 psi at 6174 rpm with 405.2 nm of torque
caldinagtt
