AE101 oil leak
AE101 oil leak
Postby Luke28 » Sun Aug 26, 2007 6:36 pm
my ae101 has an oil leak.. I had a look to find where it is coming from today and am pretty sure its coming from the sump. (from the gasket.. or goo..) does the north south beam have to be removed to get the sump off? i am getting my clutch changed shortly so would it be wise to let the mechenic fix the leak while he is doing the clutch?
Luke28
Postby sergei » Sun Aug 26, 2007 7:54 pm
Yeah, you will have to remove crossmember along with exhaust 2 in 1 piece.
It will be easier if you do it while the gearbox is out.
just make sure it is sump leaking (they rarely do) not crank/cam shaft seals.
Postby AceSniper » Sun Aug 26, 2007 8:17 pm
2nd that ^^^^
feel/look around the top edge of the sump make sure the oil isnt coming from somewere else and sitting on the edge making it look like the sumps leaking
AceSniper
Postby ChaosAD » Sun Aug 26, 2007 8:53 pm
maybe pull the top cambelt cover off and see if theres any oil in there
ChaosAD
Postby Luke28 » Sun Aug 26, 2007 9:43 pm
ok well i pulled off the cam belt cover and no oil was leaking from the top.. had a tourch under the car and didnt look to me that there was oil coming from the crank.. plus at the start of the year i had all the cam and crank seals replaced while changing the belts. the belts had no sign of oil on them. not sure what to do.. might have someone have a better look.
Luke28
Postby AceSniper » Sun Aug 26, 2007 9:53 pm
try going around the sump bolts and lightly tighten them might make a better seal, but idealy remove subframe and exhuast to seal it up again
AceSniper
Postby Luke28 » Sun Aug 26, 2007 9:57 pm
you can only get some of the bolts.. then they disapear under the cross member. ill degrese all the oil off and wait and see exactly where its coming from. if it is the sump gasket ill get the clutch guy to fix it up while doing the clutch. cheeers guys!
Luke28
Postby AceSniper » Sun Aug 26, 2007 10:22 pm
sump is just sealed with RTV or toyota stuff
AceSniper
Postby KinLoud » Fri Aug 31, 2007 3:56 pm
My 20v is leaking a bit of oil from the oil filter fitting where it bolts to the block... look there.
Ken
Ham
021 408 863
Postby sergei » Fri Aug 31, 2007 3:58 pm
KinLoud wrote:My 20v is leaking a bit of oil from the oil filter fitting where it bolts to the block... look there.
Ken
Ham
021 408 863
That is actually very common thing
Postby rolla_fxgt » Fri Aug 31, 2007 5:04 pm
Ken
Ham
021 408 863
2nd'd
try tightening it up a bit worked for me
rolla_fxgt
Postby rollaholic » Fri Aug 31, 2007 5:28 pm
just tell the mechanic you have an oil leak and you'd like it fixed :)
Postby Luke28 » Fri Aug 31, 2007 7:19 pm
rollaholic wrote:just tell the mechanic you have an oil leak and you'd like it fixed :)
lol yer.. they say the front seals had to be replaced and while we were doing that we had to do all this other crap which is going to cost you heaps. id prefere to find where its coming from before i take it to get fixed.
doesnt seen to be any oil above where the sump bolts up.. will attack it with some degreser tomorrow.. give it a good clean and go from there.
Luke28
Postby Luke28 » Sat Sep 01, 2007 9:11 pm
well i thought i would give the sump bolts a little tighten today and 2 of them snaped off 8O bugger...
Luke28
Postby rollaholic » Sun Sep 02, 2007 9:56 am
bugger indeed. guess its a bit late now but sump bolts just need to be nipped up, its the sealant or gasket which keeps the oil in.
if you think your mechanic is ripping you off, or you dont agree with him on where its leaking, why dont you go somewhere else?
Postby Luke28 » Sun Sep 02, 2007 12:57 pm
how hard it it to get the rest of the bolt out?
Luke28
Postby rollaholic » Sun Sep 02, 2007 1:34 pm
depends how tight it is really, might end up drilling it out and heli-coiling. if the broken off bolts are on a straight section, you might get away with not replacing them unless they are side by side or something.
Postby Luke28 » Mon Sep 03, 2007 7:41 pm
ok so i had a look tonight after work and almost certain its the crank seal leaking.. why would this be leaking because i had it replaced in feb this year!!! along with the crank pulley and key. Anyway whats a rough price for getting the seal replaced?? is it a hard job for someone that hasnt takin belts off before?
Luke28
Postby AceSniper » Mon Sep 03, 2007 8:14 pm
so its the oil pump seal??? there like $7
If it was replaced it might not have been put in right, or the crank has alot of wear in that area?
AceSniper
Postby Luke28 » Mon Sep 03, 2007 8:25 pm
ummm.. it lookd like it was coming from behind the bottom pulley.. is that the oil pump seal?? thought it was the crank seal behind that pulley
Luke28
