Upping compression on a 16v 4age
Postby blackmk3 » Sun Aug 26, 2007 7:54 pm
A mate of mine has a 4age in a ee90 corolla, which has since spun a big end bearing so hes going to rebuild the motor
however he is wondering if pistons from a 20v would fit in the 16V and connect to the 16V rods just to give it a bit more compression?
(puts on search flame suit) i couldnt find any posts giving me a direct answer :?
Thanks
Nick
Mk3 MA70 Supra
blackmk3
Postby ChaosAD » Sun Aug 26, 2007 8:56 pm
if its a bluetop then no. Just plane a bit off the head and use a trd head gasket.
ChaosAD
Postby rollaholic » Sun Aug 26, 2007 9:28 pm
the 20v pistons also have recesses for 5 valves, and they'll be in the wrong position for 16 valve heads
not sure if this will cause valves to strike pistons, but remember smallports are 10.3 compression ratio anyway - probably easier to use a TRD head gasket and / or plane the head a touch.
how high was he wanting to go?
Postby blackmk3 » Mon Aug 27, 2007 9:08 am
Yeah it is a bluetop tvis
Sweet thanks for that info guys
He wasnt looking for a certain compression ratio just purely wanted a bit more wack to it since the motors going to be apart anyway
Looks like a TRD gasket will be the go
Thanks heaps
Nick
Mk3 MA70 Supra
blackmk3
Postby MacrosSiR » Mon Aug 27, 2007 5:44 pm
he might need adjustable cam gears if he goes for a thinner gasket
MacrosSiR
Postby rollaholic » Mon Aug 27, 2007 6:43 pm
if its a bluetop then i reckon a smallport swap would be the way to go :P probably cheaper than a rebuild too
Postby Caveman » Mon Aug 27, 2007 7:18 pm
MacrosSiR wrote:he might need adjustable cam gears if he goes for a thinner gasket
Yep you will need adjustable cam gears with a skim or tinner gasket (or both). Timing goes out quite a bit, dont have numbers but it was significant. The adjustable cam gears are about $150 each.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby ee904age » Mon Aug 27, 2007 7:20 pm
I had silvertop pistons and rods in a bigport redtop I rebuilt. They fit, the engine turns over with head etc on but hits if cam timing is out. So it becomes an interference engine.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby rollaholic » Mon Aug 27, 2007 7:30 pm
i believe the gudegeon pins and big end bearing sizes changed from 18 / 40mm to 20 / 42mm respectively on the smallport onwards, so fitting 20v pistons to an older engine would mean using complete silvertop internals
Postby ChaosAD » Mon Aug 27, 2007 7:39 pm
ee904age wrote:bigport redtop
Its just the bluetop thats different.Redtop rods are heavier/stronger than silvertop but cranks the same
ChaosAD
Postby matt dunn » Mon Aug 27, 2007 8:11 pm
rollaholic wrote:i believe the gudegeon pins and big end bearing sizes changed from 18 / 40mm to 20 / 42mm respectively on the smallport onwards, so fitting 20v pistons to an older engine would mean using complete silvertop internals
Much earlier than that.
The early bluetop had the 18mm pin and 40mm crank,
and everything else from then on has the 20mm pin and 42mm crank.
Postby 3T-Rona » Mon Aug 27, 2007 9:21 pm
all i did was get a 20v(silvertop) from a wrecker mate, whip off the head, and crap (water pump, alt) and clean it all up and slap on my 16v head (all new gaskets and shit) so it still has 20v pistons and rods, goes fine, maybe even 'mean' loses traction often enough to get me in trouble although i do have nana bickey wheels....
3T-Rona
