however he is wondering if pistons from a 20v would fit in the 16V and connect to the 16V rods just to give it a bit more compression?
(puts on search flame suit) i couldnt find any posts giving me a direct answer
Thanks
Nick
MacrosSiR wrote:he might need adjustable cam gears if he goes for a thinner gasket
rollaholic wrote:i believe the gudegeon pins and big end bearing sizes changed from 18 / 40mm to 20 / 42mm respectively on the smallport onwards, so fitting 20v pistons to an older engine would mean using complete silvertop internals
