exhauast - blitz nur and kakimoto
Postby LEV_101 » Thu Aug 30, 2007 10:57 pm
hi ,
i have two exahust for my car but i still dont know which one to choose.
what i want to know is the differences between the two. performance wise.
blitz nur barrel type 2.5 inch inlet. and goes inside barrel and and the tip is 4 inch but when i look inside the barrel it is more of 2 inch out.
kakimoto - 2.5 inch inlet and straight though and out 2.5inch
why is the blitz exhaust 2 inch out ?
what is best in performance wise?
thanks
LEV_101
Re: exhauast - blitz nur and kakimoto
Postby barryogen » Fri Aug 31, 2007 2:33 pm
LEV_101 wrote:what is best in performance wise?
The end muffler will make 2/5s of f**kall difference unless it is overly restrictive, which neither of these will be.
I assume(from your user name) you have an AE101 Levin, so 1600, NA?
Any mods?
Assuming none, it probably wont matter which one you have on there, so much heat will have dropped from the exhaust temp by the time it gets to the end of the pipe that it will be far less dense, and would probably flow out a 1.75" pipe quite happily.
barryogen
2ZZ Guru in training
Postby LEV_101 » Fri Aug 31, 2007 3:53 pm
Any mods?
i have a altezza 3sge. i use to have a 101 :lol:
so wont make a differences ?
mods are pretty much headers, no cat, intake, plugs, all the normal stuff.
thanks for your response
LEV_101
Postby barryogen » Fri Aug 31, 2007 5:10 pm
LEV_101 wrote:i have a altezza 3sge. i use to have a 101 :lol:
From memory factory they are a 2.25" or 2.5" aren't they?
Cat out it will probably buzz like a Honda.
Probably wont make a hell of a lot of difference which one you use...
barryogen
Postby ChaosAD » Fri Aug 31, 2007 7:26 pm
I know some of the 2 1/2" jasma n1 style mufflers, have a smaller perforated tube going through them to help quieten them down. Cant be great for performance.
Is that what the blitz is like?
ChaosAD
Postby LEV_101 » Fri Aug 31, 2007 9:07 pm
ChaosAD wrote:I know some of the 2 1/2" jasma n1 style mufflers, have a smaller perforated tube going through them to help quieten them down. Cant be great for performance.
yes, thats right .
still dont know which one to choose thought.
LEV_101
