silvertop > map sensor
Postby Pies » Sat Sep 08, 2007 3:49 pm
How does one go about using silvertop quads in a map sensored setup? as apposed to afm...
Current Rides:
Pies
Re: silvertop > map sensor
Postby Rick » Sat Sep 08, 2007 4:33 pm
Pies wrote:How does one go about using silvertop quads in a map sensored setup? as apposed to afm...
By using an aftermarket computer or a blacktop 20v wiring loom, ecu, map sensor etc...etc..
Postby 85AW20v » Sat Sep 08, 2007 4:44 pm
I "think" there might be a vacuum pickup you can use off each of the TB's but you will also need some sort of damper to smooth out the vacuum pulses, especially lower in the rev range.
See ya
Simon
85 MR2 20v
85AW20v
Postby sergei » Sat Sep 08, 2007 5:19 pm
Simon85MR220v wrote:I "think" there might be a vacuum pickup you can use off each of the TB's but you will also need some sort of damper to smooth out the vacuum pulses, especially lower in the rev range.
Nope, there is no need for that, there are plenty of vacuum pickups on the gearbox side of the manifold. You will still need damper for MAP (like in all cars anyway).
Users browsing this forum: Bing [Bot] and 15 guests
